Originally posted by bimmerfan08
F8X M3/M4 CF Drive shaft mod
*Should* be a reduction in harshness on abrupt throttle changes and shifting. Vibration will increase if the balance wasn’t good, and it is a bit harder to balance the longer shaft, although the stiffer/lighter carbon helps mitigate this. Otherwise, I’d estimate no noticeable impact to NVH.‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
Yeah those things definitely make this mod appealing. But still waiting on radii measurements to see if there will be any actual inertial reductionOriginally posted by Bry5on View PostCarbon has the extra benefit of stiffness and more inherent damping. The reasons I’m interested in this are for those two and an inertial reduction to help with the clunk when shifting. Would love feedback from anyone who’s done a back to back on those metrics. Seems worth a shot!
Found some pretty good info from bmw blog:
http://www.bmwblog.com/2021/04/09/vi...bmw-m3-and-m4/
The guts:
Video from the linked blog post:
https://www.youtube.com/watch?v=gVqHSron50U
At 1:00 in the engineer mentions f8x carbon driveshaft is 90mm heinzboehmerLast edited by meowth; 01-15-2024, 08:50 PM.
- Likes 3
Clever, I wonder what adhesive is used that’s able to be removed. That might also be useful on our driveshaft and half shaft CV splines..Originally posted by meowth View PostFound some pretty good info from bmw blog:
The guts:
At 1:00 in the engineer mentions f8x carbon driveshaft is 90mm heinzboehmer‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
Ooh that cutaway picture is great. Can estimate wall thickness pretty well with that. Now we just need someone to cut open a stock driveshaft and measure the wall thickness at all its different diametersOriginally posted by meowth View PostFound some pretty good info from bmw blog:
The guts:
If you have a driveshaft out I can ultrasonically measure thickness without cutting anythingOriginally posted by heinzboehmer View Post
I run a YFCM carbon driveshaft. I did a before drive in the mountains and then directly after the install. The shifts definitely feel more direct and the clunk is a lot less noticeable. No increase in NVH whatsoever. Installing a 1-piece driveshaft is a PITA. Had to drop the rear differential to get it in.Originally posted by Bry5on View PostCarbon has the extra benefit of stiffness and more inherent damping. The reasons I’m interested in this are for those two and an inertial reduction to help with the clunk when shifting. Would love feedback from anyone who’s done a back to back on those metrics. Seems worth a shot!2002 M3 Carbon Schwarz/Black 6MT
- Likes 4
Drop the diff entirely? Or just remove the front bolt to allow movement of the front of the diff?Originally posted by slavik1988 View Post
Also have the YFCM DS and had to remove the front diff bolt and loosen the rears. I didn't have to lower the subframe though. I really wanted to avoid loosening the diff, but I just couldn't get that extra 2 to 3 mm to slip into the front diff flange.
On a side note, the weight savings of the YFCM DS is where it shines, IMO. As Slavic mentioned above, shifts are "more direct and the clunk is a lot less noticeable". There is also faint whirl sound at high speeds over 100+ mph like an electric motor. lolLast edited by Epsilon; 01-17-2024, 07:26 PM.
- Likes 4
I wonder if it might be viable to make the shaft a tiny bit shorter when cutting the flanges, to allow the expanding/contracting portion to cover the install without diff removal. I have no idea how much wiggle room there is in that joint.
how is it on the F8x cars with this driveshaft when it comes to install/removal? do they also have to loosen diff? or is the F8x DS flange adjustable/telescoping to allow install/removal with out touching the diffOriginally posted by Obioban View PostI wonder if it might be viable to make the shaft a tiny bit shorter when cutting the flanges, to allow the expanding/contracting portion to cover the install without diff removal. I have no idea how much wiggle room there is in that joint.
Yes it's telescopic by the diff. It probably can be retrofitted into the e46 if pinon size is the same.Originally posted by nextelbuddy View Post
But parts can't be bought separately you most likely need an f8x diff to dismantle.
In the BMW video, they state the CF diameter is directly related to max RPM, which IIRC is 7k on an S55.
Any thoughts on how this relates to spinning the S54 8k+?'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Email to [email protected]
