Went for a drive, lost power and now car exhaust sounds like it has cams
    If they did not remove the securing clip for the oil pump disc and left the VANOS unit completely stock, then there might be a problem with that VAC exhaust hub. Otherwise, it would be an installation issue like heinzboehmer said.
    In your picture, I cannot see the securing clip or washer for the VANOS oil pump disc. That is a strong clip that retains the ring that has now fallen out onto the exhaust hub.
    Haha touche
    Build Thread:
      These photos seem to show that the retaining ring that holds the outer race of the pump disc has popped out and the outer race is what he's moving with the pick?
      If so it seems possible that if the retaining clip wasn't seated properly that could have caused the rest of the destruction subsequently?
      It's been a while since I did mine but from memory that seems plausible no?
      I'm not sure what the term is for the part, but that is the ring that the four oil pump pistons push against and it rides on the needle bearings in the VANOS unit.
        Yeah agreed. If that retaining clip wasn't seated properly, or the oil pump pistons weren't seated properly then that could be the cause of this too. The “bearing” damage could be subsequent to that. All depends on exactly what OPs mechanic did/didn't disassemble.
        Build Thread:
          Update from the shop:
          So what happened is the piece in the upper right came out
          https://beisansystems.com/wp-content...mage075-14.jpg (https://beisansystems.com/wp-content...mage075-14.jpg)
          What is odd is the snap ring is still in place.
          All the needle bearings are out in the oil pan so we are going to need to flush the engine oil
          https://beisansystems.com/wp-content...mage082-13.jpg (https://beisansystems.com/wp-content...mage082-13.jpg)
          The Beisan vanos would work and we can flush out the oil pan.
            The snap ring isn't in place in the photos you posted earlier.
            Edit: unless it’s part of the needle bearing casing?
            Build Thread:
              No idea but I just ended up buying the Beisan Vanos unit and their exhaust hub and having it shipped to my shop. Hopefully after that my Vanos issues will be fixed.
                It does not come with exhaust hub. Since you already put a $700 upgraded VAC hub on the car I assume you want to keep it?
                Call up beisan and see if they can sell you a rebuilt VANOS with tbd OEM pump disc hole size.
                Thanks for this. I ended up just buying their exhaust hub as well as the unit itself. My VANoS system should be bulletproof now right? Haha I even changed out the solenoid stuff earlier too!
                I shall have a slightly used VAC exhaust hub for sale soon. Didn’t want to mix parts.
                thanks for the help!
                  Not sure how that is physically possible if you look at how it is assembled -
                    To be honest, I don’t know what I am looking at
                      Exactly - something doesn't add up
                      Build Thread:
                        Yea not sure what to really think. I don't have enough technical knowledge to refute what they are saying. Once again, this is a very well known and popular shop in SoCal so I doubt they would lie. I've been going to them ever since I had my f80 years ago.
                        I guess I can find another shop after the fact, but I already bought the needed parts and they just need to install it and be done.
                        Anyone know of a shop more dedicated to e46 M3s in SoCal, particulary in LA? My friend mentioned JMP but any more recs are welcome.
                          This video explains the components and how they are assembled, skip to 8:40 -
                          For major or technical work, it might be worth driving to Kaiv in SD.
                            There’s a guy in Pico Rivera that is a killer with VANOS work. He’s a Beisian-certified VANOS technician (I think that’s what they’re calling him).
                              Got it. Do you have their info?
                              Lama from beisan sent me some recs too. Odd that the pico rivera guy isn’t on the list below:
                              Here are some shops. Just let them know you spoke to Beisan systems and I recommended them. And they will take care of you. Best of luck. And let me know if you need anything else.
                              Bertone Motorsport
                              Nouran Doumanian
                              2250 W Main St
                              Alhambra, CA 91801
                              (626) 300-8915
                              (626) 300-8915
                              [email protected]
                              Bavarian Professionals
                              Eric
                              1218 7th St
                              Berkeley CA 94710
                              (510) 524-6000
                              [email protected]
                              North Bay Bavarian
                              James , Bryce, Richard Row
                              1801 Empire Industrial Ct.
                              Santa Rosa CA 95403
                              (707) 545-0820
                              [email protected]
                              Achilles Motorsports Inc
                              5636 W. San Madele Ave
                              Fresno CA 93722
                              (559) 276-5715
                              (559) 307-0484
                              [email protected]
                              Craig/Neil Motorsport
                              343 Airport Road
                              Oceanside CA 92058
                              (760) 721-5500
                              (760) 521-4689
                              Jon Ho Shop
                              8797 Irvine Center Dr
                              Ste L
                              Irvine CA 92618-4208
                              (714) 653-6045
                              [email protected]
                              Josh Johnson
                              7493 Reese Rd.
                              Ste B
                              Sacramento CA 95828
                              (916) 367-3350
                              (916) 400-4456
                              [email protected]
                                He’s on their installers page: https://beisansystems.com/installers/
                                Mario Giovanni / Salvino Rodriguez
                                email: [email protected]
                                Tel: (562) 202-0136
                                Address: 90660 Pico Rivera (Los Angeles area)
                                Instagram |@Tier1Euro
