I’ve got ST40s under 18” RG-Rs on my e39 M5, with no issue…
I’m talking about a test fit of the E39 spec front RGR on the front of an E46 M3 with 996 front brakes. That fitment isn’t close. The M5 front hub must have the brakes mounted further inward — I know people only need small and sometimes no spacer to run Brembo GT kits on that chassis as well.Originally posted by Obioban View PostI’ve got ST40s under 18” RG-Rs on my e39 M5, with no issue…
Thanks for chiming in Tbone, Obioban & Repoman;
So in short, the E46-spec RG-R can clear 996 BBK with spacers, and as offset on RG-Rs is determined by the barrel position, a rather conservative offset is actually beneficial in this case.
And since the E39-spec RG-R is already sitting pretty far out at 8.5 width + ET22 and it will be difficult to slap on a decent-sized spacer on them, thus it won't work for 996 BBK. Yea?
Yeah, an 8.5 ET22 is already about right for street width and offset IMO, I personally wouldn’t want to push that out further. A less aggressive offset with a spacer would work. It would annoy me to spend all that money on wheels and have them not fit properly though so I haven’t done it. RGRs have increased in price quite a bit in the last couple years too.Originally posted by Sprp85 View PostThanks for chiming in Tbone, Obioban & Repoman;
Thanks again for the input! I guess its either get a new set of wheels or stick with the stock brakes... Which wheels, for street duty, did you go with?Originally posted by repoman89 View Post
Stuck with the ZCPs that I already had and added spacers. I want 18s but the car doesn’t see a lot of street miles anyway since I normally just drive the M5 or my wife’s Mazda, and drive to the track on my TA16s.
They look good and haven’t been destroyed (yet) by our cracked and pothole covered roads.
What width and offset are your TA16s, and do you use a spacer with them?Originally posted by repoman89 View PostStuck with the ZCPs that I already had and added spacers. I want 18s but the car doesn’t see a lot of street miles anyway since I normally just drive the M5 or my wife’s Mazda, and drive to the track on my TA16s.
9.5 ET35 square for easy tire rotations with 12mm spacer in the back for even fitment. There is inches of clearance front and rear.Originally posted by Nate047 View Post
If I was to buy them again I’d get ET22 in the back to avoid spacers and just get the tires swapped once halfway through their service life.
Kind of a tangent, but why wouldn't you just do square ET22 at that point? Presumably track alignment would have enough camber to allow for that fitment on the front, or?Originally posted by repoman89 View Post
That would probably work too!Originally posted by Nate047 View Post
My interest in “serious” track time is waning a bit honestly — it’s fun but not quite ~$1000/day fun. I would love to find one (spacerless) staggered wheel setup to do it all and just run PS4S or maybe PSC2, and not worry about the understeer bias that such a setup causes too much. Probably why I’m thinking about custom LMs more seriously than I should.
I’m here to peer pressure you into doing the LMs.Originally posted by repoman89 View Post
