    Still need to drop mine off for paint, but here’s a local friends car that just completed install on his.
    ILB - yellow / so classic Click image for larger version
    2006 ILB | M-Texture
      Originally posted by designer485 View Post
      Hi guys, here are few photos from my recently finished install.
      Love the classic logo. How did you manage that? Looks great!
        I created the logos in Illustrator and then custom cut vinyl stencils for masking. Then I painted the logos on with Rustoleum Caliper Paint.
          Does anyone know if these parts numbers will work? These came off a 2001 911 Porsche Turbo.
          996.352.425
          996.352.426
          996.351.429
          996.351.430
            For those with a squeak, Porsche has this TSB out right now about it. Basically the pad is unevenly mating with the rotor surface due to lack of pressure. Maybe when things heat up, the surfaces change directions just enough to cause that low speed squeal. The Macans are all having this problem so it was cool to read the explanation. Their problem happens when a light layer of pad builds up and cause uneven mating. According to Porsche, this is normal operation. One hard brake fixes it.
            The weights are on the pads to help dampen oscillations during hard braking. Low speed pad dragging is a different story though. Through hard braking, everything is vibrating hard they have really done well with controlling the vibrations. The PCCBs are part of that solution. THAT is a kit I'd love to see on an E46 M3.
              996.352.425
              996.352.426
              996.351.429
              996.351.430
              No, you need 996 Carrera calipers
              996.351.425, 996.351.426
              996.352.422, 996.352.421
                If you want carbon ceramics, the F8X CCM system is probably as bolt-on as the F8X blue calipers.
                  I'd never want it on my car 😂 that's like $3k a rotor.
                    Will the Porsche Brembo calipers clear ARC8 18x9.5 ET35 front wheel?
                    Didn’t see a definitive answer from Pawa’s post before, Apex’s site implies that it does.
                    ‘04 M3
                      I would get 5mm spacers to be safe but it should.
                        Ok thanks - after getting these wheels I’m really reluctant to do anything to push them out further outboard due to rubbing/aesthetics. This is primarily a street car with some HPDE.
                        ‘04 M3
                          You won't need spacers.
                            Well there you go. That saves a few dollars off the swap.
                              Did you guys install the brake shims below or can you leave them off?
ID:	75254 Click image for larger version
ID:	75255 Click image for larger version
                                I installed mine. They help reduce noice from the piston contacting the pad.
