Originally posted by WOLFN8TR
For anyone wanting to match brembo red, I've gotten pretty close with VHT engine enamel where there are a few reds to choose from like Ford red. VHT caliper red is darker than Brembo's as Repoman found.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I used Testors Gloss Red and it matched perfectly. I've read it does darken with the heat from braking. I cured mine at 250 and they didn't darker hardly at all, time will tell.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
1 PhotoLast edited by WOLFN8TR; 04-06-2020, 02:41 PM.TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
Originally posted by WOLFN8TR View PostI used Testors Gloss Red and it matched perfectly. I've read it does darken with the heat from braking. I cured mine at 250 and they didn't darker hardly at all, time will tell.
I cleared mine with VHT earlier and it’s looking good, hazing is gone. The texture and look is slightly different vs where I taped it off but I’ll live with it
Originally posted by bassel_sy View PostCan we sticky this thread please, and give Tbone a medal whille we at it.
Thoughts on using Anitseeze when installing the new dampers in the pistons to prevent sticking in the future?TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Lol thanks guys. Good idea Gary!DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
No, only csl. You'll need 18s iirc.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by Tbonem3 View PostNo, only csl. You'll need 18s iirc.
Those are some big ass spacers. Based purely on offsets and wheel sizing, CSLs could use a 10ish mm spacer then (can’t know for sure due to spoke differences unless someone who’s tried can confirm). Might be time to upgrade ..- 2006 AW/IR Manual
- Karbonius Race / Alpha- N
- Supersprint
- KW V3
- 996 Brembo
- ZCP / PSS
If youre rockin' stock wheels (with high offsets), which csls and zcps are, you're likely to want at least a 12-15mm F spacer anyway. My csl rep's native et is 32 (vs. 44/47), and I still run a 10mm spacer.Last edited by Tbonem3; 04-08-2020, 02:23 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by Tbonem3 View PostIf youre rockin' stock wheels (with high offsets), which csls and zcps are, you're likely to want at least a 12-15mm F spacer anyway. My csl rep's native et is 32 (vs. 42/47), and I still run a 10mm spacer.- 2006 AW/IR Manual
- Supersprint
- KW V3
- 996 Brembo
- ZCP / PSS
The issue of front clearance keeps coming up, and for whatever reason people seem to need WAY bigger (like 18mm) spacers to achieve clearance.
See my (filthy) current front setup: OEM ZCP wheels + 996 calipers, RR bracket, 12mm spacer
There is a good finger's worth of clearance - probably like 15mm.
Again, these are my experiences - don't know if there are any physical differences between cars (shouldn't be), but felt the need to post this as I could probably get away with a 5mm spacer and have enough clearance to run these calipers and wheels.
996 Brembo hub face to caliper outer face measurements:
Front: 35.5mm
Rear: 17.9mm
Last edited by mainstreamer00; 04-08-2020, 12:50 PM.TiAG 6mt Coupe | KARBONIUS | SUPERSPRINT | FIKSE WHEELS | OEM CSL | MILE END COMPOSITES | AST 5200 | HOTCHKIS | BREMBO | RECARO | BEISAN | CATCAMS | CP-CARILLO | TMS | RTD | ROGUE ENGINEERING | AKG MOTORSPORT | HTE PERFORMANCE
I'm running the zcp/csl wheels ,10mm rear, 12mm front w/ 75mm race studs , u think ill clear tyler?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
