MSS54 DS2 Tool: FREE TOOL for programming DME - Tune, full binary, flash counter, etc
    nice one! I don't know where I got 80 degrees from then!? could have sworn that's what it was for ISTA when I checked, but checked again and it's 75 there too. Will amend. Yeah I decided the no errors in the DME condition wasn't worth doing, especially given people are probably running these tests when diagnosing an issue, it didn't seem like a realistic condition. I get what they're saying in that if there's an issue with the module being tested the test won't be successful, but that's kinda the point haha.
    All good. The E-Box fan test worked ok for me too.
    Would it be possible to display the DME temperature in the that test also?
      Sorry to take this thread a bit off-topic, but could anyone send me MSS54.prg and/or MSS54HP.prg?
      Now I am genuinely wanting to test my ebox fan and can't as I only have MSS54DSO.prg which apparently does not allow for these tests.
      Seeing as Karter's tool won't engage the fan yet seems to work fine for others I'm sure its not his program, yet I would still like to try tool32, but can't w/o the correct prg.
        I tried the CSL flap test with and without the engine running.
        Makes a somewhat loud buzzing sound for less than a second and produces this error message.
        Click image for larger version  Name:	20260530_150814.jpg Views:	8 Size:	129.3 KB ID:	356963
        Click image for larger version Name:	20260530_150251.jpg Views:	0 Size:	36.4 KB ID:	356962
        Okay so you got that error because the conditions for the test were not met. The conditions that must be met are:
Name:	Screenshot 2026-05-31 at 4.48.07 PM.png
        b_diag is definitely !=0 because the app is responsible for setting diagnostic mode over DS2 and the app would have errored out earlier if it couldn't set this.
        N (engine speed) must be less that 1000rpm.
        bit 6 of gks_ed must be 0. Bit 6 identifies whether there are any current (active) CSL flap errors in error memory.
        If you're able to validate you were doing the test with the engine not running, or with it at warm idle less than 1000rpm, and also check error memory and see if you have any CSL flap (GKS) errors would be the next step I think.
          attached is 12MSS54.PRG. I don't have MSS54HP.PRG.
          Don't suppose you happen to have the DTC for the ebox fan disabled? That could also cause what you're seeing with the test not being able to run.
            Interesting, I did have these codes, but cleared them before doing the test, and none were hard faults. I'll give it another shot just to be certain.
            A few months ago I had cracks in my strut tower welded, I removed the DME and also de-pinned all wiring associated with the CSL snorkel as to have the wiring out of the way.
            I have since driven the car and all seems well with the flap but this indeed could be a contributing factor as to why the test didn't run.
            I'll try to sort this out and report back.
              Ah interesting. I'm pretty sure that if you'd cleared them first and they weren't hard faults then it shouldn't have blocked the running of the test, I am fairly sure that the bit 6 in GKS_ED will only be set if the code is active/hard.
                This I do not know, the tune was a standard CSL then HTE did some work latter on, that would seem to be an odd DTC to suppress, but I definitely cannot say one way or another.
                  yeah agreed that it would be super odd, just thought I'd note it just in case!!
                    I tried once more and had the same type of almost electrical arcing noise for a moment and incomplete test.
                    These shadow errors are indeed now hard faults.
                    I'll explore further tomorrow, I'd sure love to get this test working, must be something with my wiring, odd.
                      With the caveat that I haven't experienced it myself, if you watch YouTube videos of the flap test running that electrical arcing noise seems to be a normal part of the process as far as I can tell.
                      Re shadow codes 99 and 89, they are normal/expected. To check that the error reporting system is working correctly the DME intentionally triggers those two codes on a regular basis as a test. You can disregard them. I've included them for completeness, but you're the second person that's brought this up, I wonder if maybe better for the app to suppress these two codes (or at least note that they are expected/nothing to be concerned about)
                        IMO it would be best to suppress when the counter is zero. Which I believe is basically what INPA and DIS/ISTA would do
                          This is the noise, that makes me feel better as does your explanation of the shadow codes.
                          I will try the flap/ebox tests again with tool32 tomorrow using the different prg file, thanks for all the feedback and all this work you have done, this is fantastic.
                            Is it worth saving the HTE tune with the tool and flashing back to standard to see if the E-Box fan test works or if there are any E-Box fan errors?
                            Apparently, you can also activate the E-Box fan with INPA, though the activate section, although my version only had the radiator fan motor.
                              I may just do this, I want to test this stupid fan now, it's odd my DME won't allow the test.
                              I opened up my BIN in Martyn's binmod tool to find the option to suppress DTC's for the flap is indeed activated.
                              This is likely a very standard setting for tuners as not many people run the CSL flap.
                              I did get the flap to activate using the pictured command in tool32.
                              It "buzzes" for ~4 seconds, stops, I command it again and the flap opens/shuts, same as the video I previously linked. I don't know if that person had to command it twice as I did however.
                              I wonder if that command is finding the stop points, as "adapt" is in the title?
                              Also, would having the DTC's suppressed (assuming no flap related codes are present) have an affect on the DS2 Tool's ability to test?
                              Side note, still not able to test ebox fan on tool32 or DS2, might need to test it with direct voltage somehow.
                              Click image for larger version  Name:	20260531_145516.jpg Views:	0 Size:	73.5 KB ID:	357051
                                Okay great thank you so much - this is it. The test command does indeed need to be sent twice. Found a video on YouTube as well that confirms this. I'll make a fix for this and get it released. Thank you so much for your help with this!!!
