MSS54 DS2 Tool: FREE TOOL for programming DME - Tune, full binary, flash counter, etc
    Random thought I had the other day, which is tangentially related to this effort. Does the DME expose functionality (via DS2 or otherwise) for disabling the fuel injectors at crank time?
    Think it would be super useful for priming the oil system.
    erm good question - I don't know but will look into this, you're right, it would be very useful.
      I don't know if you can trigger DTCs via DS2, but that might be a hacky way to go about it, if there isn't some official way to do so in the program. For instance, unplugging the crank sensor will stop the injectors from firing, so there might be a way to take the same branch if the appropriate DTCs are set?
        Possible yes, but I'm not sure if it really fits with the intent of the app which is more about the programming/diagnostics side of things. There's already a fair few options out there for DS2-based gauges etc. so I hadn't envisaged the app going in this direction.
        In terms of gauge type options I think the way to go is something like the Gauge.S that does CAN logging, so you can get 100hz data. Paired with the upcoming v2 of Community Patch you'll have the ability to log and display literally any variable in the DME that you like. The actual code for v2 is finished, I'm just still madly working on all of the documentation to go with it to make it useful for people.
        Sorry, by dashboard i just meant a table of the values like in the DIS screenshots. I guess some or all may be available form 'Live Values' already.
          You might be able to do this just by keeping your foot on the throttle pedal when cranking the engine over, since the car will not start with the throttle pedal fully down.
            Ah sorry I misunderstood. Yep I get what you're saying, basically go to live values, select which values you want to monitor and then just display those in one view to see them. Yep can definitely do that!
              Just gave this a shot and, unfortunately, the car started right up
                Strange. A Mastertech told me that and used it to perform a compression test on my engine. In fact, i helped him. I cannot remember if it was me in the car or him. Probably me while he read the gauge.
                You must have the throttle pedal down before you spin the car over is all i can tell you. Perhaps i was running standard firmware rather the CSL at that point.
                  I think that is the general rule of thumb when carrying out a compression test - hold the throttle wide open. I never bother personally.
                  he probably just pulled the fuel pump fuse or in clipped the injector rail
                    With the S85 in ISTA you can disable the fuel injectors, that would definitely be cool on the S54 as well, but pulling a single fuse in the glovebox is easy, easier then a laptop imo.
                    As far I am concerned this tool does enough, especially for the price, but if karter wants to keep going I certainly won't argue!
                      Thank you karter16
                      This is impressive! I believe it will help me solve my EML issue.
                      Edit: The DS2 Tool did enable me to properly test/compare a suspect TPS to a known good TPS. Using the data logging capability, and throwing the data at AI, I have high confidence it's a failing TPS causing the EML, and not a wire.
                      The detail in Error Memory, and the elegant solution for capturing the Error Memory in file and dropping it in the History folder was also extremely useful.
                      Hi folks, I have a 2005 with about 170k miles on it. I'm converting it over to a track car for HPDE, so it's under stress routinely and I need it to be reliable. Given that these events are costly, I'm trying to address the typical causes of downtime before I go to the track. One cause is the drive-by-wire throttle that
                        Hi karter16 Is there a roadmap of new features coming to the DS2 Tool?
