This is a sticky topic.
    I think so. You have to get it hot enough, but steel is easier to work with than any alloy.
    You have a proper torch?
    A long pry bar or something would be good to give you the leverage. One end down below that step, then the otherside of that step will be your fulcrum. I like your idea of pulling too. I would mock it up and practice first. Can this fit into a vice or can you make a quick jig or something to hold the whole thing? Maybe even in-situ if you had to.
    Or take it and an 18 pack to a local muffler shop.
      Unfortunately the best torch I have is MAP gas, I think I can vise that bitch up and give it a go. I just worry about cracking the welds, it bent one way (likely from a crash) now I am bending it back.
      I do like how the resonators are clamped on so worst case I can just delete them or get new resonator as both sides are bent up. The exhaust is likely going to be super tame with 2 sets of resonator but the M6 isn't getting high end shit, that's for the 3 series.
ID:	292177 Click image for larger version
        Have a proper dumb question for this thread this time; when removing the axle from the differential does any diff fluid come out? Need to repair the inner cv joint boot and was wondering if I’ll need to have some Castrol diff fluid handy or it’s actually a sealed unit and I'm being dumb?
        2004 CB/Cinnamon 6MT Coupe
        Youtube
          You won't lose any diff fluid. The output shafts are bolted to the drive flanges on the differential, so they just get unbolted. Now if you want to replace the flange seals on the differential, then you might lose some diff fluid.
            Okay - getting ready to install 996 calipers on the Imola. This question is partly lazy and also partly “I’ve read everywhere up and down and can’t get someone with the exact setup I want to run give me an answer”:
            ZCP wheels
            275/30/19 rear
            245/35/19 front
            What spacers can I run without issues and on stock suspension? I measured and *think* I can run 15MM up front and 12MM rear still without rubbing?
            David
              ZCP wheels
              275/30/19 rear
              245/35/19 front
              David
              I'm running 12.5 in the rear and 20 in the front without issues and it looks great.
                I’m assuming you responded because you have ZCP wheels and these tire specs and stock suspension, but… yes? lol
                  Anyone who has DIY'd diff output seals: what did you use to drive the seal in? I remember it being a huge pain in the ass to get it in last time, and I would like to be prepared this time so I can get in and get out. Anyone know of an easily purchasable object that will do the trick?
                    No, to be clear I have the 19" style 67 wheels. I'm sorry, I should have mentioned that.
                      Regarding the suspension, I have the Koni/Eibach shock/spring combo. I'll attach a link to this setup so you can see the amount of reduction from the springs (it's not much). https://www.bimmerworld.com/Suspensi...1145-1012.html
                        I used a PVC pipe fitting, although it was a special fitting I got from a store I used to work at that sold hot tubs. It was a repair fitting so you won't find it locally but here are some pictures and a part #.
                        I see I sanded it around the permiter slightly for a better fit. My memory is terrible but I'm almost positive I used this.
                        Edit: You may be able to get this locally, it slips over a 2" fitting, we sold them as well as another shop in our small Nebraska town.
                        Click image for larger version  Name:	20250131_194433.jpg Views:	0 Size:	36.7 KB ID:	292627 Click image for larger version  Name:	20250131_194439.jpg Views:	0 Size:	39.2 KB ID:	292628 Click image for larger version  Name:	20250131_194451.jpg Views:	0 Size:	39.0 KB ID:	292629
                          They've got it on amazon. Amazing. Thanks man!!
                            https://www.amazon.com/Waterway-429-.../dp/B00GXDW9OI
                            Just don't hate me if it doesn't work, again I am not 100%, but a solid 85.999%
                              What's the shelf life of brake fluid? Asking about fluid in a previously opened container but the fluid isn't used, and brand new in a sealed unopened container. If I check the moisture is that a good enough indicator that it's good or not?
                              '01 M3, Imola/black
                                Unopened and sealed is good forever. If opened for more than a year (and I write the date I opened it on the bottle) it gets pitched.
