This is a sticky topic.
    Anyone running RE trans mounts?
    I'd like to go OEM but they are $90 pop, ridiculous. The RE mounts seem like they might not incur an NVH penalty as they are neoprene and the bolt doesn't go all the way through the mounts.
    From the description they just changed the shape from and hourglass to cylindrical, although I don't doubt the rubber may still be a bit more dense.
    I love RE trans mounts. They're basically E21 mounts (but with 8mm stud for our braces whereas e21 has 10mm). No NVH, just beefier.
    Now which were you referring to going from hourglass to cylinder? RE mounts have always been cylindrical, and I doubt that BMW would change e46 bushings' shape at this point in time (unless they've been changed to fit newer models, and are backwards compatible with e46).
      Thanks for the info, I'll likely go with those. The stock are hourglass and RE's cylindrical from what I understood. That simple change in shape led to a bit less deflection.
        I run the RE mounts on almost everything, no issues.
        Email to [email protected]
          Been running into an issue recently where after the car gets hot, the throttle when I rev-match doesn't rev as freely. When the car is cold/hasn't been at temp for very long, the rev-match works as it should but after a while it feels like the throttle is almost getting stuck and maxing out around 3K. Has anyone ever ran into this issue? Is my TPS going haywire when it reaches a certain temp?
            Anyone got recommendations for street pads for the STOPTECH ST60 and ST40 setup? Thanks.
              Bear with me… Is there any reason why Koni yellows would not work with Ground control camber plates? Just would like to make sure before I purchase some new shocks, my car has GC plates installed.
              thanks
                thanks
                If your current GC plates work with the factory dampers, then the Koni yellows should be plug and play since the Konis can be installed with the factory top mounts.
                  Unless you can find another factory car that uses the ST60 D1247 pad shape, you are stuck with ST Street, ST Sport or other D1247 aftermarket pad. The ST40s can use Textar 993 pads with some light machining to the backing plate.
                    thanks
                    What shocks have you now? Few, only very high end that I can think of, use 14mm. Most are 16mm like stock, bilstein, koni. The thing with plates is more about the perch size (stock, 2.25, 60mm, 2.5). Doesn't sound like you're changing springs.
                      Currently have Sachs shocks. Car has H&R springs already so looking to install a shock that is more appropriate for lowering springs. Thus why considering Koni Yellows. Thanks
                        https://www.zeckhausen.com/catalog/i...Kv49jgf5bnyNsg
                        Thanks bud. I'll check those out too.
                          I hate to even make a post like this, but is there a generic door panel clip that actually holds properly and long term? I bought some on Amazon and I swear I have broken more than have held, trying to put my interior back together.
                          '01 M3, Imola/black
                            Click image for larger version  Name:	IMG_4795.jpg Views:	0 Size:	34.8 KB ID:	283357
                            How are they breaking? During install or removal? Guiding them in before pressing in the door panel will prevent crushing them.
                            FCP has them for 0.69 each from the OE supplier. 51418224781
                              Don't buy aftermarket trim clips. The plastic is more brittle and the dimensions are just slightly off.
                                Thanks, yea they would just not quite fit, then you pound on the panel a bit and they break.
                                '01 M3, Imola/black
