Originally posted by fattycharged
Ah interesting, I was wondering why even with the fender pull the lip wasnt flat and still so thick. Thanks, yeah that sounds like a better solution, ill try that instead of cutting, less chance of accidentally cutting a spot weld too lol.
EDIT- following up, after taking another look at the inner lip, the shop that pulled the fenders pinched the top of the lip ‘channel’ closed, so wont be able to get a wire wheel in there to clear out the rubber :/
There are spot welds are on the inboard side of the U shape, if you cut off the entire channel, your inner and outer arch will no longer be connected to eachother, you can solve that by welding the entire perimeter, which is what I have on my personal car, but obviously it will need painting on the outer arches at that point, you also need to be careful of heat control and warpage.
Another approach without welding is to first cut the U shape into the L shape, by removing the inner edge with the spot welds, and then carefully only cut out the inner arch part of the L shape, not the outer arch part, then apply panel bond adhesive and fold the outer arch over the now cut inner arch, and seam seal it afterwards, that is how a CSL is from factory.
Here is a CSL for reference.Last edited by bmwfnatic; 01-10-2025, 02:58 PM.E46 ///M3 • 12/2002 • phönix-gelb • 6MT
- Likes 4
I was tightening the cylinder head bolts and one of them, number 12 in the diagram, was just a little easier on the resistance side than the rest of them. I was still able to get the 30nm+90+90 degrees, I used a snapon techangle, but it just was smooth unlike the rest had which had more of a tight/clamping feel. I cleaned the bolt holes and used compressed air beforehand but now I'm rethinking if somehow maybe there was residual brake clean or I lubed up the threads with too much oil (used an oil can and just went down the threads, not much imo). It could just be OCD. Any experiences with this/insight?
1 PhotoLast edited by sbay; 01-15-2025, 10:42 AM.‘02 TiAg/Impulse Slicktop
Originally posted by sbay View PostI was tightening the cylinder head bolts and one of them, number 12 in the diagram, was just a little easier on the resistance side than the rest of them. I was still able to get the 30nm+90+90 degrees, I used a snapon techangle, but it just was smooth unlike the rest had which had more of a tight/clamping feel. I cleaned the bolt holes and used compressed air beforehand but now I'm rethinking if somehow maybe there was residual brake clean or I lubed up the threads with too much oil (used an oil can and just went down the threads, not much imo). It could just be OCD. Any experiences with this/insight?
I'm sure someone else who has done a headgasket will chime in, but I would not overthink this and you really can't go back and redo it. If you marked a line on the bolt, you can come back and check that it is still in the same position in a few hundred or thousand miles to satisfy the OCD. If the cams are in, even more incentive to keep going forward. You also used a techangle and it is hard to mess up with one of those.‘02 TiAg/Impulse Slicktop
Originally posted by PSUEng View PostI'd like to know how to check if the original engine is still present in the car. Buddy of mine is selling a car with a swapped motor and I'd like to help him disclose that. Is there an engine serial number plate with part of the chassis VIN in it, or is this confirmed another way?
2003 AW/BLK 6MT - Instagram
I need to do the driveshaft center bearing, and MAYBE the driveshaft CV joint. Long story short, I have a clunking sound after leaving my driveshaft not properly supported for a long period of time while doing my RACP. Stupid, I know. I'm inclined to believe, or at least, hoping, the center support bearing is the culprit.
1. Are there any non Genuine BMW center support bearings that are as good and lower cost? (Yes I know they are only like $150 to start with)
2. Are any of those fasteners one time use only? Or can I reuse everything?
I am going to try just doing the center bearing first, and if the clunking problem persists, then I'll drop the shaft and do the CV joint. So I'm hoping I can reuse everything if I need to drop it all twice.
Originally posted by Nate047 View PostI need to do the driveshaft center bearing, and MAYBE the driveshaft CV joint. Long story short, I have a clunking sound after leaving my driveshaft not properly supported for a long period of time while doing my RACP. Stupid, I know. I'm inclined to believe, or at least, hoping, the center support bearing is the culprit.
Originally posted by Nate047 View Post1. Are there any non Genuine BMW center support bearings that are as good and lower cost? (Yes I know they are only like $150 to start with)
I was running INPA and the laptop slid off my lap. I accidentally pressed F7 reset adaptations while the car was running. How screwed am I? Thanks2003.5 BMW M3 Carbon Schwarz Metallic/Cinnamon 6 Speed – HTE Tuning | Kassel CSL DME | AA Headers | AA Section 1 | SS Resonated Section 2 | SS Race Section 3 | TMS V2 CSL Airbox | TMS Street Plates | Ohlin’s R&T Coilovers | Ground Control Front and Rear Sways | Ground Control Adjustable Camber Arms | DMG Autosport Pro46R | FreakyParts BBK Front | Porsche 996 Conversion Rear | CMP Stage 1 + 1.5 Reinforcement Plates | CMP Subframe Bushings | CMP RTAB’s | SGT CSL Bumper | SGT CSL Trunk | Dr VANOS
Adaptations get reset when the battery is undone as well. You'll be fine. Will take some time for smog monitors to set.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I bought a used full exhaust system for my M6, supposedly Dinan, at least the mufflers. My issue is that one of the resonators is bent on the outlet side.
I don't know much about metal, welds etc. so I wondered if this could be fixed by me maybe with some heat/pliers/leverage.
