e46 M3 Tire Sizing Thread
    Appreciate the feedback, one of the other reasons I was looking at larger sizes is tire rack is out of the OEM size rear tires in the ECS2s
      Those will fit. For a stock car, I'd probably just stick with the stock tire size. Modern tires are already very grippy compared to the PS1/2s the car came with. CSL used a 235/265 if you want more tire for a stock car. The ECS1 in the 235/265 has plenty of grip for the street.
      Edit: Another reason to keep the stock tires is the extra sidewall, tire profile - 40/35 vs 35/30 - for a little more ride comfort.
      This. Depending on your rim size, I'd do 235/265 or 245/275. 235/265 is a nice street setup that tracks normally and has no weird tramlining.
        Personally, I'd spend the extra $150 for the Michelin PS4S before compromising on tire size.
        Also, you'll notice that the 225/255 PS4S combo is available in two different flavors. The less expensive one with the load/speed ratings in parenthesis is the OE BMW Star tire.
        2003 Imola Red M3 w/ SMG
          Interesting point on the rolling diameter. Has anyone experienced any real world effects of this?
          Although I'm changing these, I noticed my car came with 225/45 front 245/40 rear on stock 18's.
          Based on this it the front would be taller than the rear. I haven't noticed any negative performance from dsc. It is an Mk20 if that matters.
          🔹 2001 M3 Laguna Seca Blue
          Build thread: link
            It never ceases to amaze me as how fatty these rear rims and tires can be on these cars
              Originally posted by Sprp85 View Post
              Hey all-
              Has anyone run 275/40R18; all around, on E46 M3?
              Offset will be standard setup for squared wheels - ET35 with spacers in the rear.
              I did run 275/40R18 in the rear at one point and found them to be a tad too tall but never done them up front.
              Also interested in hearing people's experience with this setup and whether their car is lowered.
                You have to have the right suspension in the front for them to fit correctly. If you run a 6" spring, it's a high chance the lower spring perch will be right where the rim wants to be with a 10" wide rim. I had this problem, but swapped to a 5" spring, which raised the perch enough so everything fits nicely now.
                  Hello All! I recently rejoined the M3 ownership club, adding an E46 to my garage. It came with some CSL wheels, not sure if OEM or replicas but the tire sizes on the car now are a bit confusing as mounted.
                  275/30/19 in the front, 275/35/19 in the rear. I don't know the exact wheel sizes but this seems out of spec to me. Should I be putting the current fronts on the rear and getting 245/35/19 up front? Thoughts? Any help would be much appreciated!
                  Last edited by Jshowers72; 07-28-2025, 12:21 PM. Reason: removed inserted photo...
                    Welcome! And congratulations. I'm going to assume it's running a square setup, that's why it has such a large tire in the front. So in a square setup, the front and rear wheels are the same. They look OEM from the pictures, but it can be hard to know for sure unless you inspect them closer.
                    There is nothing wrong with a square setup, that's what I run in my car, but it will tramline a bunch, and the front steering can be twitchy. Really, it's personal preference and driving style. If you want a more OEM driving experience, swap out the front wheels for a set of "front" sized ZCP/CSL wheels and a smaller 245 tire. I'm sure you'll have a line of people willing to trade you straight up.
                      Hey guys, I bought a set of 219M wheels that are in fantastic condition. With the sizes of:
                      Fronts 18x8.5 ET29
                      Rears 18x9.5 ET23
                      I know I can fit 235/40/18 with 265/35/18, but would 245/40/18 with 275/35/18 fit with OEM suspension? I don't plan on lowering it anytime soon, might keep it the OEM suspension forever to be frank it's my summer/weekend car. I just got some OEM Sach struts with the OEM springs for the rears and the supporting parts last year.
                      I am just asking as I know the offset with 219M isn't ideal/is a bit more aggressive, especially the fronts.
                        Fronts 18x8.5 ET29
                        Rears 18x9.5 ET23
                        Yeah, that should clear with 275s - but suspension and other things can get in the way. So measure twice, buy once.
                          I have a few questions, would 255/40/19 fit in the rear with no issues? If so what size would I put in the front to match?and lastly would a squared setup of 255/40 work? Thanks
                            I don't see why they wouldn't fit, you're just gaining ride height not inset or poke. 255/40 is the stock rear tire size so you can use the stock tire size in the front which would be 225/45/19
                            If you had a set of four rear (18x9) style 67s then 255/40 square would work.
                              I have 19” style 67 19x8 front and 19x9.5 rear
                                255/40 for a 9.5 is within spec, but you could run into DSC issues as the circumference between front and rear will be off by 3.7%.
                                I'm assuming 225/40/19 in the front.
                                Edit: I wouldn't run a 255/40 on an 8 inch wide wheel.
