    Winter projects wrapped. Nogaros and Coby wheel
      Going back to CSL intake.
      but I wanted to reinforce all port connectors and the inner posts as there were some spots where I felt more could be better.
      I found this product to be perfect, only downside is the color but is internal so not a problem
      Click image for larger version  Name:	IMG_1762.jpg Views:	0 Size:	149.1 KB ID:	298822
      And once applied and smeared around it looks like so.
      One of my rivnuts had become loose and was spinning freely so I fixed it and applied some epoxy to all others to future proof it.
      Click image for larger version  Name:	IMG_1763.jpg Views:	0 Size:	192.4 KB ID:	298821
      I also put back the boots using OE worm clamps
      Click image for larger version  Name:	IMG_1764.jpg Views:	0 Size:	100.5 KB ID:	298823
      all lined up inconspicuously
      Click image for larger version  Name:	IMG_1765.jpg Views:	0 Size:	140.2 KB ID:	298824
        Click image for larger version  Name:	IMG_6030.jpg Views:	3 Size:	199.4 KB ID:	298839 Hit the 1,200 mile mark after completing my rebuild. Got it tuned yesterday by the one and only HassanEido. After a year and a half of sitting, saving, and researching…I can finally say, I did it. 8K has never felt better. Would I buy a car with a blown engine again? Probably not. Was it worth it? Hell yeah.
        Also my 333rd post on this forum.
        ‘02 TiAg/Impulse Slicktop
          Had the same issue with the OEM lenses, felt like they would break before compressing the new gaskets, old ones still in as a result.
          I had the same issue when redoing my OEM lens and did the same thing as far as reusing the old seal. It eventually ended up getting dirty on the inside of the lens somehow, so then I just fought and swore my way through installing the new ones. There was some dude on YouTube that had some tips and tricks I think I looked at - but it was a PITA, no doubt. I do remember taking the whole damn light out and doing it on a table instead of trying it while on the car. Ever since the new seal it's been all good.
            Completed the installation of the CSL intake ancillaries. Brake booster vacuum line and IAT sensor
            Mocked up in place. Need to replace PS hoses and many more things before I can drive her again.
              That CSL Prototype style Engine Cover looks so sexy
                Redid the headliner & batwings Click image for larger version
                  Swapped on some Powerstop drilled/slotted rotors and new carbon fiber pads, painted the calipers black, added 20mm spacers up front, and finally installed the Motorsport Hardware stud conversion kit:
                  Oh and stripped my oil pan drain plug, yay.​
                  2005 BMW M3 (6MT) Instagram
                    Just pulled my headlights last week getting ready for the season. Disassembled, cleaned and put in fresh gaskets. They're a pain in the ass but its also in large part to L/R alighnment of that lens vs. the clips. There is some leeway and it's easier to get it to snap shut all around when the clips are aligned in a specific way.
                    I do this every year and when i didn't get it to snap shut all around in the past, moisture would get into the lens when I'd wash the car. I also have ocd and YMMV.
                    2006 BMW ///​M3​
                    ig: @marecki.e46
                      Pulled the CSL trunk out of storage, it has a 09/22 build date. I have all the accompanying OEM pieces to install at the same time, I remember reading somewhere that the screws were incorrect though?
                      Anyway, I've completed the license plate lights wiring, using the guide found on these boards.
                      I plan on test fitting everything tomorrow, so far it looks fairly plug and play, Karbonius seems to have fixed the inner tail light issues this batch.
                      Sent from my Pixel 9 Pro XL using Tapatalk
                      Pretty sure I got one from the bad batch. Body shop had to do some trimming to get everything to fit just right.
                        Got bored so decided to slap on Dinan ITBs on the LSB. Keeping this as a collector of sorts, so it's getting the full Dinan S2 treatment.
                          Finished the throttle body install and the Dinan CAI… pain in the ass.
                            Doing CMP topside reinforcement in my LSB, still need to do sealer and body filler before final primer coat and that LSB base coat and matte clear.
                              Put back the unfiltered section to test fit the black hardware. The stainless steel hardware was just too flashy.
                              now I kind of find annoying that the carbon parts don’t match each other. The previous MAF box had the same shade and shin as the engine cover, but the old Karb is a bit more gray and is 1x1 v 2x2.
                              should I sell my Karb for a new one 🤔
                                Spacers after the KW install couple weeks back
