    Filled her up for the first this season after a spirited drive around town!
    2005 BMW M3 (6MT) Instagram
      Originally posted by robgill View Post
      My full set of Karbonius carbon fiber trim arrived for the street car build. Looks amazing 😀
      Unfortunately the car is still at the body shop in the New Rochelle quarantine so it's going to be a while before I get it back 😑
      Wow, I knew their stuff was good but that looks incredible.
        Did a valve adjustment, many were out of spec. I notice absolutely no difference in power or anything really.
        Also re-wrapped the armrests since they had seen better day, what a YUGE difference it made to the interior. I used a product called Ultra-leather (from the makers of Ultrasuede {made by Toray or a subsidiary, whom are also the makers of the official alcantara [I think I have all that right]}). Anyway, stuff is amazing. Perfect matte finish, has a nice hand and the grain is a perfect fit for the interior.
        Click image for larger version  Name:	old armrest.jpg Views:	15 Size:	37.7 KB ID:	32562Click image for larger version  Name:	new armrest.jpg Views:	15 Size:	58.5 KB ID:	32563
          I think the placebo wore off of you a long time ago
            Finished rolling the rears, added 10mm spacers, and slightly raised the ride height.
ID:	33015 Click image for larger version
ID:	33017 Click image for larger version
            - Nabil
            2006 Interlagos Blue ZCP
            IG: @nfaridi
              Some nice DIYs in here
                Takata Low Down Slopes!!! I have a set of those - so useful! You must be an OG JDM guy.
                  Awesome!
                    Haha! Yessir, coming from an Evo X and RSX before that. They are life savers for sure.
                    Awesome!
                    Thanks! I was able to get the front jacked up today and did the strut mount swap trick to get some extra camber. Was rubbing the fenders on turns before. Still needs some tuning but its much better. Also adjusted the end links to remove the pre-load and get rid of some end link squeak.
                    - Nabil
                    IG: @nfaridi
                      More work in the shop. Got the 3/4" RapidAir MaxLine system plumbed and pressure tested today. Couple small leaks to fix, but it's functional, and more importantly will flow all the air my compressor can feed it and then some. Click image for larger version
ID:	33636 Click image for larger version
ID:	33637 Click image for larger version
                        Changed the dead battery with a new braille replacement. Thankfully it started right up. Took a drive to celebrate and made a pitstop at an empty JFK.
                          Did valve adjustment. Should I be trying to get those .009” gaps down to .007 or .008 or just move on with life?
                            Please don't be fooled by all the people thinking/spouting that mid spec is best. It's a spec RANGE. If you're in the range per BMW, you're IN SPEC. You're done.
                            Smaller is not better.
                              Finally found a brushed aluminum set clean enough to invest in. Been looking a long time and sure enough got it here in the forums.
                              Just finished swapping out all the trim. I really dig it
                                That’s what I wanted to hear.
                                Thanks.
