    With the BBS RS2
      With the BBS RS2
      Looks amazing
        NGK DCPR8EKP spark plugs and Eldor R3516S00100 ignition coils.
        I had these plugs sitting in a parts box from two owners ago, unused. While I have records of two valve adjustments (one of which was for the Inspection II at 60k, but there was no line item for new plugs; car currently has 96k. Last valve adjustment was 94k), I have no record of when/if plugs were changed as part of this. When I went to install them, two of the ignition coils weren't seated fully (missing the gold plug on the inside), and I'm kind of surprised the car ran well and wasn't throwing codes.
          Installed a new Karbonius CSL trunk to replace the ECS trunk that had huge panel gaps and lifted in the corners.
          very happy with how this fits.
            Currently my interior is getting work done with AMX and just installed an Airbox with flap.
              Changing the covers on the CSL seats is a big call! make sure you hang on to the original covers! Both the Amaretta suede and the laser fabric centres are NLA. Looking forward to seeing the end result!
                I would love to do the same to my or csl interior. Can you ask them to see if they can make patterns and ill buy them from them and install myself?
                  Took it out for a Malibu canyon run
                  2002 TiAg/M-Texture
                    Installed the armrest delete center console.
                      Yes, the fronts are inserts that are held by Velcro, so I can changed it back easily. The rear bottom seats will be completed replaced with new foam so I will still have the original seat…and lastly for the back, it’s held on my clips and staples so it’s pretty easy to switch back.
ID:	349122 Click image for larger version
                        Sunset drive
                        IG: @limited.slip
                        Alpine White 1 Series M Coupé
                          Found out today that the complimentary car wash from my mechanic wreaked havoc on my 8 year ceramic coat. My detailer had to do a Stage 1 paint correction and will be doing a ceramic reapplication in short order 🫩
                          2002 TiAg/M-Texture
                            With the BBS RS2
                            While I actually do like the look of stock wheel on Z4M, these BBS and similar-looking wheels really make them pop. I ended up putting ZCP wheels on mine, and absolutely love the look.
                            Yours look great.
                              A common color but it really is fantastic in terms of appearance. I've always loved my Titanium and feel like it really shows off the lines of the car.
                                Yours look great.
                                I would really like to put 18" BBS E88 on mine. Already had the 19" BBS RS2. I also have a set of CCW Classics 18x9.5 et32 that I need to redo the centers in silver.
