    Mullet tune, I can't quite put my finger on it, but this is definitely the best tune I have had on the vehicle. I flashed tune/cleared adaptations and have maybe driven around town for 3hrs so far.
    I have had the stock CSL tune (with US cam changes) and 2 different, very popular tunes on the car.
    The last tune I had was from likely the most popular tuner and was remote tuned on a dyno, not saying that is the end all be all, but just noting.
    This mullet tune feels like a more complete tune and around town driveability is markedly better, I'll stick with it!
    Thanks Bry5on for putting this together.
    It's the best tune for these cars, I laugh when people that haven't tried it express doubt.
    Instagram: @logicalconclusion
      It's only for cars with the CSL intake, correct?
        As I understand it yes.
        I wanted to also drop a Bryson appreciation post; big mullet tune fans in this house. I thought —well it’d be neat to take it to partee racing (sorta kinda close by) and see if we can dial it in even more at some point in the future; but having lived with it for a month and + 1k miles including a 450mi round trip to the mountains recently w wife and the dogs, the car is awesome, not even sure I care to do that. Shit slaps.
        Bryson is a good fella.
        06 ZCP Individual Sapphire Black Metallic
        ig: na_csl
          Pretty sure Partee would steal it and reverse engineer it so I don't think that's a good idea.
          Yep, only for CSL intakes. MAF tunes usually have the best drivability but the Mullet tune has it all.
            My plan to finish my car up this weekend has gone up in smoke. Was chasing the threads of the bolt holes on the engine block where the oil pan bolts go, to clear out the excess RTV that was in there, and was using the Lang Racing M6 tap chaser, and applied a bit too much force. Did not realize it was a blind hole, as all the other holes I had done so far went all the way through, and could see RTV coming out the top still (it was squeezing out the tiny pinhole, which made me think it was a regular hole). Nothing I have has "bit" onto the smooth shank so far, even vice grips and Knipex cobras, they all just slip through. Tried using a drill chuck but that was slipping too, so I ordered a stud extractor which would basically work like a chuck. I have used penetrating oil, and just got some MAPP gas to try and heat up the block, but have no idea if any of it will work.
            I have never tried welding before and am loathe to buy all the bits and pieces I'd need just to half-ass an upside down messy attempt to weld a nut on, so that's currently not an option.
              Wow that's a mess, and all b/c some dumbass slopped RTV all over everything.
              If I were in your situation with the Knipex Cobras (which I don't actually have, but need to get) slipping, I would consider cutting that stuck bit shaft off at the break to create a flat surface and then use my Japanese screw extractor kit on it:
              EDIT: Looks like Amazon sells this, and some other ANEX products (I got mine in Japan) you could try if you wanted to that include an M6 extractor.
              Click image for larger version  Name:	IMG_3369.jpg Views:	0 Size:	143.8 KB ID:	614106
                Do you have the needle nose vise grips that have the red "keyhole" on the end thats allows you to REALLY crank it down? Those really have some bite.
                Maybe flatten two sides of the broken extractor as well for extra purchase.
                  I do, and I have tried but I am deathly terrified of breaking off the shank and leaving it flush inside the block. I was planning on flattening the 2 sides to see if I could get that extra grip, I just need to file them carefully since the shank is already so small.
                  PSUEng, I do have an extractor that says it'll work with the M6 but I was waiting to use it as one of my last options, since like you mentioned I've got to cut it flat. And yes, I've really come to despise the shop that did all the work on the car and slobbed RTV everywhere. I've got pictures of how much I've removed but even then it only shows like 1/4-1/3 of the total, it's actually absurd.
                  I never thought I'd be dealing with this at the last moment, but I'm going to keep at it and hopefully come back with a success story.
                  Edit: Already messed up more, I cut the shank flat which helped me to drill for the extractor, and I guess that was a bad idea since when I tried to back it off with the extractor the shank split in two on one side... I stopped so it didn't come apart but I guess I am stuck now waiting for the stud extractor to come in on Sunday. If THAT doesn't work, I'll consider learning to weld.... I was planning on getting setup and learning that next year but I guess I don't have a choice.
                  Edit 2: The shank broke... The chaser is now sitting nearly flush with the block...
                    What brand of tap are you using that broke like this?
                      beemer_guy get a pair of these pliers. This will be the best purchase you've ever made. https://www.amazon.com/dp/B00NBSVYOY..._b_fed_asin_ti tle_3
                        Click image for larger version  Name:	image.png Views:	23 Size:	231.2 KB ID:	614195​
                        I actually do have something very similar to those haha. As I said, I struggled to get any grip with anything, and unfortunately the shank snapped to be almost flush with the block, so my two options are currently either try another attempt at using an extractor or weld it. I just bought a flux/stick welder and will practice before attempting it, but I tried contacting mobile welders/etc I'm the area and no one was interested so it's on me to do this...
                          It was from the Lang Racing kit, LAG-971. Since it's M6 and the shaft is so thin, and the steel so hard I imagine that it was more brittle than I expected, since I didn't have any experience in doing this before. I didn't have any issues chasing the other holes, and this was the only one where I had some pressure, wiggled it back and forth and I guess overloaded it.
                            A quick polish and a lot of stuff from the community here.
                            Installing the MAP kit from COVID-19 and switching out the HTE tune to Bry5on's Mullet tune (had to be picky on who uploads it so they don't steal it). Also got Bry5on's fender braces in from sendcutsend. Reverting back to stock injectors and a spark plug refresh. Putting in the autosolutions kit (thanks to adr_M3 for the assist in getting it) with a new illuminated broomstick (shoutout to davidinnyc for being the plug). Putting in the battery cutoff toggle that used to come with these cars back in the day so I don't drain the battery and can let the car sit once rainy season begins. bigjae46 is building out the mount and brackets in carbon for heinzboehmer's triangulation brace, the E86 braces just came in and i have the cabin housing and plug pieces, insert and dowels being printed in PA6-CF so should be here soon. And last but not least, Slideways hooked it up with a Siemens CID module to go with my system coming in from carphonics.
                            Click image for larger version  Name:	Screenshot_20261103-115032_Gallery.jpg Views:	0 Size:	103.2 KB ID:	614414
                            Click image for larger version  Name:	Screenshot_20261103_123225.jpg Views:	0 Size:	85.7 KB ID:	614406
                            Click image for larger version  Name:	Screenshot_20261103_123232.jpg Views:	0 Size:	63.4 KB ID:	614407
                            Click image for larger version  Name:	Screenshot_20261103_123239.jpg Views:	0 Size:	71.0 KB ID:	614408
                            Click image for larger version  Name:	Screenshot_20261103_124647.jpg Views:	0 Size:	72.5 KB ID:	614409
                            Click image for larger version  Name:	Screenshot_20261103_123256.jpg Views:	0 Size:	130.6 KB ID:	614410
                            Click image for larger version  Name:	Screenshot_20261103_123248.jpg Views:	0 Size:	218.2 KB ID:	614411
                            Click image for larger version  Name:	Screenshot_20261103_124638.jpg Views:	0 Size:	124.3 KB ID:	614412
                            Click image for larger version  Name:	Screenshot_20261103_124709.jpg Views:	0 Size:	75.4 KB ID:	614413
                              siamkazi how much was the broomstick? Everywhere I see them at like 500+, maybe ill reach out to the guy you got it from
                                Hell yeah! I'm excited to see those nylon parts. Did you use service that can print them as one part? Or will they still require assembly?
