    Well, to kick off, not a whole lot! I drove to the grocery store. COVID-19 has me locked in.
    put gas in it since it was super cheap.
      I didnโ€™t locked you in...
      Today I only put gas. $2.97 in Northern CA
      Budget CSL MAP Conversion
        Iโ€™m nowhere near done, but for the last week I have slowly been helping the car look better. Itโ€™s from Northern, CA and has been absolutely blasted by the rocky soil. It looks way better, but Iโ€™m not even half way done filling in the rock chips and Iโ€™m about 10 hours in so far. Worth it for me though!! Iโ€™ll post pictures when Iโ€™m done.
        Build Thread
          Got a whole bunch of things ready to install:
          Chase bays kit for steering refresh (EDIT: I have since removed this a long time ago, it simply does not work. It overheats and it leaks, do not buy.)
          330 steering rack
          Power steering pump
          Structural foam
          New exhaust hangers
          Rear cross brace
          Unfortunately I have not had access to the workshop to install it (covid). Will post pics (maybe a diy if needed) after parts are in.
          2002 E46 M3 TiAg Coupรฉ >> full tracktool conversion @m346gt
            Was going to change oil and do general inspection, but CCA DIY event was canceled. Oil doesn't really need changing based on mileage but was finally going to do Blackstone analysis.
              Good drive with clear roads - one benefit of COVID
              โ€˜04 M3
                Took delivery of it! Just got off the truck from California. 2002 Topaz Blue 6spd, single owner. Now living its retirement life on the east coast.
                Click image for larger version  Name:	 Views:	0 Size:	183.6 KB ID:	807 Click image for larger version  Name:	 Views:	0 Size:	176.0 KB ID:	808
                  Nice! Fellow Topaz owner here.
                  I was going to go for a drive today, but upon pulling into the gas station I heard a noise in the engine bay that turned out to be a shredded belt. I cut off the shredded buts, reseated what was left of the belt and limped the car back home. Yellow oil light came on when I turned off the car at home. After some investigating, I think the belt shifted after it was splashed with oil and that caused it to shred. I think the leak is coming from the front main seal, so I'll tackle that as soon as I get the parts. I remember seeing a thread about making a tool to install this seal with a cut up bottle or something like that on M3Forum. Anyone remember this too? I'm having trouble finding it.
                  On a more positive note, I finished up my CSL airbox install earlier this week. I converted my MSS54 to be able to run CSL engine management and a MAP sensor. Couldn't have gotten this done without NZ_M3's and Terra's help. Thanks again guys!
                  โ€‹
                    My full set of Karbonius carbon fiber trim arrived for the street car build. Looks amazing ๐Ÿ˜€
                    Unfortunately the car is still at the body shop in the New Rochelle quarantine so it's going to be a while before I get it back ๐Ÿ˜‘
                      Man that looks good. I wish they weren't so pricey I'd pick up a set.
                      Current:
                      2003 BMW M3 ยท Coupe ยท 6MT - Alpine White/M-Texture Alcantara
                        Tranny fluid, fuel filter, and removed my cdv. Only screwed up one crush washer. I tend to do that.
                          Today we pulled the vanos and replaced it with a low mile one. Our intake advance timing was a little slow and we already replaced the solenoid pack and adjusted the oil pressure with no change. This is likely our last go before completely giving up and living with the barely out of spec timing.
                          On another sad note, it seems one of the jack pads is now crooked so I'm guessing the metal has started to give way. I've heard people talk about this problem before but not sure what to do about it. I figure I'll ask the body shop when I get the Vince Bar installed to see if they can do anything.
                            Ran new NiCopp brake lines from front to rear. East coast rust is real
                              Got to take him out of the garage-mahajal hibernation for an hour Friday, for a joy ride as that is his purpose in my life...
                              This year, in Oregon, we have had an unusually dry winter, weather opportunities have presented driving my beloved E46 M3 through local, extended, rural twisties...๐Ÿ™‚
                              Cheers,
                              Cody
                              '04, manual, Dinan Stage 1 suspension and engine flash.
