    Very nice, are you running the stock or CSL airbox?
    Evolve CSL
      Originally posted by ra2fanatic View Post
      Evolve CSL
      I swear HTE's signature on here says 385whp, how the hell? I know he modified an airbox and part of the exhaust as well, but 385whp NA?? Maybe I am just remembering that incorrectly?
      In any event, great car with some badass parts, respect for the OE cams.
        I had a coolant leak, thought it was the lower radiator hose, and ordered a new one. I went to swap it out last night and found out that it was actually leaking from the coolant temp sensor and not from the hose where it connects to the radiator. Pulled the coolant temp sensor out and sure enough, the rubber o-ring was crushed hard and brittle. By some weird luck, I had accidentally ordered an o-ring a few months back by mistake and it just happens to be the correct size! It looks like BMW does not sell that specific o-ring separately, but if you want to replace your o-ring on your temp sensor its BMW part number 13621743299 i.e. "air temp sensor o-ring" fits perfectly.
        Super easy took a few minutes and didn't even need to drain the coolant.
          All good man. I don't intend to be searching for every little ounce of performance. I know there are those that probably made that number just with the airbox prior to me even doing cams and headers, but I'm not sweating it. Rides and feels nice. She'll be in hibernation soon enough after I do some additional work on her this week and then off to the next vehicle project after.
            Wasn’t technically today, but this past Friday, I ordered the full carbon Karbonius CSL style intake.
            2005 BMW M3 (6MT) Instagram
              How did you go about having this done? Very cool.
              Hot Wheels customizer on Instagram from Thailand. Told him what I wanted/showed pictures of my car. It took me around 5 months and constant messaging for updates to get but glad its finally done and in my possession.
              Sent from my SM-G965U1 using Tapatalk
              2004 Jet Black/Cinnamon 6spd ///M3
              Build///Journal
              IG: Khan_Art_
                I have completed detailing my engine bay, all very subtle but nice details. Some will spot the add-ons / changes
                  Click image for larger version  Name:	IMG_0639.JPG Views:	0 Size:	147.4 KB ID:	87654
                  Is the black "A" structure tied into the OE strut brace and then into vehicle structure somehow? I assume that is the OE brace painted/caps over nuts, looks nice. Different coolant reservoir I see, was this done for increased capacity or to make the hole created by removing the SAP look a bit better?
                  Also, could you explain the vented piece w/ roundel on the slam panel?
                    ah! What happens is that this is a Z4M. The A brace is OE, and the strut tower brace is Z4 specific. I added a few things
                    - Nut caps to the A brace bolts
                    - Nut caps to all strut tower brace nuts
                    - I flipped the TPS connector boot 180 degrees
                    - Added strut tower caps (z4 brace does not have them as M3s do)
                    - Added a hood roundel to the radiator cover
                    - ///M oil filler cap
                    - added convoluted cover to the red ecs high pressure vanos line (OE look)
                    - installed an alpha-N IAT harness to avoid a loose / hanging MAF connector, and zip tied it to the expansion tank return line so the harness runs parallel to it all along.
                      Nice, obviously I'm not familiar with the Z cars, not many around here. I too would like to clean up my bay as with the MAP/IAT/FLAP and unused MAF on Turner harness plus halos, it's getting to be bit crowded.
                        I just got a hardtop for my ‘04 vert! Nobody noticed at first since it’s the same color as the cloth top lol. Makes the car look way sleeker imo.
                          So is that main strut bar one from an e46 M3 that has been stripped down to bare metal or is that what they look like when they come on the z4s?
                            The bar is Z4 specific, and finish is bare aluminum. There was a point in time I wanted the black M3 but I am fine with it now
                              Used a product called Solution Finish to fix my whitening windshield trim.
                              Then I chased down a rattle from when I installed my headers. Found the passenger side header was resting on a heat shield. Bent the shield a little out of the way and no more rattle.
                              Build Thread
                                Removed my window tint. Was a real sh**show 🤣
