Help diagnosing high water temps at track - Resolved? (not really!)
    wait wat?
    removing the thermostat in an S54 closes off the radiator? I can't say I've looked at it that closely, but that would surprise me.
      wait wat?
      It doesn't close off the radiator, but the water chooses the path of least resistance and without the thermostat it will chose to get sucked back into the water pump instead of traveling into the radiator. The thermostat housing has two separate chambers, and upper and a lower. Water exits the engine and travels into the upper housing. From there it can fall into the "closed" or rather compressed thermostat opening, or exit the housing and travel into the upper radiator hose to the radiator, or a combination of both. From the radiator the water travels back to the thermostat housing and into the lower chamber of the thermostat housing. From there, because of the suction the water pump creates, it falls into the water pump and travels back into the engine.
      When the engine heats up and the thermostat "opens" it actually raises up, or becomes erect into the upper thermostat housing. As it raises into the thermostat housing it closes off the hot water exiting the engine's ability to fall back into the water pump and instead the route out the upper chamber and into the radiator becomes the lower resistence.
      In essence, the function of the thermostat is to divert water flow more than act as a barrier of flow. If you remove the thermostat the hot water exiting the engine will always choose to flow back into the water pump instead of to the radiator.
        Originally posted by S14 View Post
        The thermostat on and S54 car is not a barrier type thermostat..
        You're right and I wasn't thinking clearly.
        The way it works is the Tstat cylinder moves up and down as a gate to let coolant pulled in by the pump from the radiator return hose (when cylinder is up) or from the head (when cylinder is down) or a mix between the two sources.
        To bypass the Tstat one needs to find a PVC tube or thin metal tube with the OD the same as the Tstat cylinder OD which is about 1.9" (to be verified) and cut to 1.8" length. One end of the tube is inserted into the Tstat housing top cover and the other end needs to have a cutout 1" x 1.5" (for radiator returning coolant to be pulled by the pump) as pictured below.
        With the tube inserted into the upper cover, it blocked the pump from sucking the hot coolant from the head, and this forces the pump to suck in the radiator cooled coolant in via the tube's 1"x1.5" cutout.
          Piping in here. I was experiencing overheating at the track late last year and was mystified, much like you. I had already replaced the entire cooling system and figured I was just pushing the car beyond its limits, but it still bugged me because my times weren't much faster than before. Later on, a water leak developed and I discovered the thermostat housing and water pump both leaking. I now suspect that the water pump was just starting to fail which is why I started to see overheating at the track. Those small leaks cause pressure losses in the system which reduces the cooling efficiency.
          I think when everything is working, a fully OE system should be able to keep up with all but the most extreme ambient temperatures or a highly modified car. Sometimes stuff fails unexpectedly early (my water pump was only 3 years old with ~20k miles on it), so when you have some time, inspect everything very carefully.
          Hope that helps.
            Or you could take an old thermostat and modify it to stay in the open position.
              Hope that helps.
              Thanks for this insight! Yeah havent been able to look into the car since my last post, and dont have any track days planned or coming up. Have barely even driven the car in 2 weeks other than to run some errands. But yes hoping I find some small leak I wasnt seeing before and it ends up being that it was the small pressure loses causing the overheating. Thats my first step is have the cooling system fully inspected by my indy since I cant seem to find anything wrong myself.
              And for the guys going off topic on the t-stat operation; my car is a full on street car with a/c, full interior, sound system, etc. Regardless how the t-stat operates I'm not modifying it... I shouldn't have to. My cars just a stock n/a S54 with bolt-ons and tune lmao.
              Btw i did post the dyno graph with AFRs.... I dont see any one commenting on that? I figured someone would mention it looks a little lean on top compared to the B-spec baseline tune?
              Also could a failing fuel pump cause a lean condition, in turn causing the engine to run hot? So many damn variables...
              2004 CB/Cinnamon 6MT Coupe
              Youtube
                Bumping this up, haven't had a chance to really touch the car since my last post (just been sitting in the garage gathering dust, no time these days ) but was hoping to have some feedback or inputs since my last post lol. Guess I'll just take it to my indy when I finally have some time and hope he can figure out whats the issue.
                Youtube
                  providing vacuum to the system and refilling the coolant under vacuum might be a way to clear any air pockets.
                  Also, I modified a coolant cap in my S50 swapped E30 by blocking the bypas vents and adding a tire chuck. I was able to give the cooling system a very slight positive pressure status where I found a small hose leaking at the joint that while static, didn't leak at all. Replacing the hose solved a temp problem I was experiencing.
                    Random Question: Have you removed the A/C from the car? I left the A/C in my track car because I don’t want to transition to a coolsuit just yet because I drive the car 45 minutes to the track and back. Once I fail NC State inspection I will buy a trailer haha.
                    I personally have only experienced high track temps in the following situation. Sitting in the car in the paddock I turned on the A/C for a couple of minutes while the prior run group exited the track.
                    About 4 laps in, I was checking my gauges on a straight and noticed that the water temp was climbing towards the “second dot” (I’d have to look back at the DL to see what temps were reached) and noticed that my A/C was still on, I just hadn’t noticed it. I turned off the A/C, put the car in clean air and everything dropped back to normal. Lesson learned.
                      Nope, never turned on the AC during these track days. Car does has full AC system as its still mostly a street car.
                      What is DL? Im looking to get something that can give me proper readouts/logs of temperatures so dont have to rely on the factory gauges and have to keep watching them while I'm driving ha.
                      Might as well give an update for the thread as well: I still haven't had the time to get the cooling system refreshed My indy is 45 mins away and been working 50+ hour weeks these last few months, no track days planned especially as the weather is getting to sauna mode here. So hasnt been a big priority, but def still top of my mind to get this cooling issue resolved.
                      Youtube
                        Hi everyone, I'm so glad I found this post. I have a 2003 M3 that I use for mostly track driving.
                        I have the same exact symptoms as was BigRussia describing. The car never overheat in traffic or any other condition, however at the track, only after a few laps and it goes past the half point.
                        So far I upgraded both radiator and oil cooler to CSF, replaced WP, thermostat and fan clutch. Pretty much every component in the cooling system, and still things have not gotten any better. I also thought I had head gasket issue, but my mechanic checked and confirmed no issues there.
                        Now what's interesting, is that I also have the TTFS tune (after install of euro headers). In addition, last night I used the OBD port to check coolant temps, and I see that temp gauge goes beyond the half point at around 205 degree, is that considered over heating? is there any buffering in the stock temp gauge that possibly the TTFS tune removed?
                        I hope someone can help figure this out..
                          For what it's worth, I just wasted the better part of two months chasing issues with my CSF radiator and high coolant temps on track. I swapped back to a brand new BMW OEM radiator and it instantly solved the issue.
                          Hi All, I’m at a bit of a loss with a cooling issue I’m having. The coolant temp gauge will move up to the third dot when driving around the street (mainly with A/C on or going up steeper hills) and on track will easily move into the red. Max temp I saw on the street was 210 degrees @ ambient 90 degrees and on track I saw
                            Man that's crazy, I still havent gotten around to resolving this issue but was planning on finally taking my car to my indy shop next week for a cooling system refresh (new thermostat, wp, temp sensor) hoping that would resolve it, since im sure its a faulty thermostat. I recently got a OBD P0128 code, which is coolant taking too long to warm up to normal operating temp, so figured it must be the thermo since I've had the car too hot and now says its taking too long to warm up lol.
                            But that's discouraging that the cooling system refresh didnt resolve the issue in your case Did you install the CSF radiator after the issue happened, or already had it on the car when the issue started happening?
                            I'm really considering a retune from Frank (TTFS) as well, just hoping my indy who did the tune with him can get ahold of him while my car is there for the cooling system refresh.
                            https://nam3forum.com/forums/forum/m...e-street-track
                            Really does seem like CSF is not really an upgrade, I've had that in my mind as one of the possible causes as I've been trying to rule out everything causing this issue. I heard earlier version had issues w/ flow and clogging? Mine must be from 2016 at least. I'm considering adding a new OEM rad to my cooling system refresh job, but curious is the CSF aluminum rad even any lighter than the OEM rad? My car came with the CSF so didnt have the OEM handy to notice any weight difference.
                            Youtube
                              Man that's crazy, I still havent gotten around to resolving this issue but was planning on finally taking my car to my indy shop next week for a cooling system refresh (new thermostat, wp, thermo sensor) hoping that would resolve it, since im sure its a faulty thermostat. I recently got a OBD P0128 code, which is coolant taking too long to warm up to normal operating temp, so figured it must be the thermo since I've had the car too hot and now says its taking too long to warm up lol.
                              I'm really considering a retune from Frank as well, just hoping my indy who did the tune with him can get ahold of him while my car is there for the cooling system refresh.
                              If you're tracking the car, you should really get off the TTFS tune ASAP. Multiple engine failures from their tunes on track, and it might fix your overheating issue as a side perk.
                                I’ll post a puzzle to this crowd:
                                New OE Water Pump
                                New Hoses
                                New Coolant Expansion Tank and Overflow Line
                                New RE Street* Under-drive Pullys
                                New Zionsville Race Radiator with Spal Fan
                                New 60/40 Coolant (Water/OE Coolant)
                                Vacuum Bled
                                New T-Stat
                                New O-Rings
                                I’m considering starting with the removal of the underdrive pullys. Am I going to need to switch back to a clutch fan….Car is overheating to the second dot later in sessions, approximately 20 minutes in. Head gasket…..
                                Edit: I’ll look at the Datalogger for more accurate temps
