Front strut brace
    Directly from Rogue website, this will make more sense than my short explanation. Basically they are saying sometimes the bar won't just slip over all 6 studs. I think one or both of my towers have moved so I might be in that category.
    .....When fitting it on either an E36 or E46 with OE strut mounts, remove the 3 nuts from both sides. You can place one side of the RACEBRACE on one side and loosely install the nuts a few threads. For the other side, you may be required to lift up on that side with a floor jack to "lower" the strut stud threads move out of the way so that the bar may sit flat. Be careful NOT to jack it up too high as the entire strut may drop out of the strut tower. Once the bar can sit flat, you can lower the car so that the strut mount studs and protrude through the tower and the brace at the same time...
    that makes sense now. luckily no issues here installing fully grounded.
    πŸ”Ή 2001 M3 Laguna Seca Blue
    Build thread: link
      Originally posted by old///MFanatic View Post
      He’s saying on cars that have issue being installed normally with a one piece brace. RE suggest to lift a side so the strut mount & studs slip down. That way the brace holes line up easier to get the studs from the bottom while flush. Making it the shortest distance between brace holes and studs side to side. As opposed to at a slight angle trying to clear raises strut mount studs (making it shorter) and not able to clear the studs on one side to mount brace.
      But yes, even lowering like that with the alignment stud/nub intact I doubt the alignment would be thrown off.
      My issue is I have aftermarket plates, so I would loose alignment, no alignment pin, if I indeed had to drop a strut.
      Just trying to suss stuff out before I order things, and unfortunately I really won't know what's what until I have the product, I really think my towers are out of spec.
        He's saying on cars that have issue being installed normally with a one piece brace. RE suggest to lift a side so the strut mount & studs slip down. That way the brace holes line up easier to get the studs from the bottom while flush. Making it the shortest distance between brace holes and studs side to side. As opposed to at a slight angle trying to clear raises strut mount studs (making it shorter) and not able to clear the studs on one side to mount brace.
        Ah I understand now.
        I've never had this issue on either of our cars. Sometimes you need to man handle it to get the studs through the plate but never needed to jack up the car. And if you did I would suspect you would only need to do it once during initial install.
          Hey Cubieman - can you mark the stud position relative the strut tower? Even with masking tape that's outside the perimeter of the strut tower brace. Use a straight edge to transfer the stud alignment to some other part of the car by marking the masking tape.
          I've done lots of alignments myself on several different types of cars and even if you get it close by not perfect (back within 0.1 - 0.2 degrees, easily achievable), you're not going to impact toe which is the real killer of tires if that's what you're concerned about.​
            You won't lose the alignment if you loosen the top bolts and support the wheel. Use a floor jack and jack up the tire if the wheel has to be up. Just don't roll it, bounce it...or even breath on it! J/k about breathing on it.
            It is an extra pain the ass...I get it. I remove the OEM strut bar quite a bit. I don't get why the strut bar base plates need to be made to such tolerances I hope they don't think the strut mount studs are the main lateral load path (or whatever the technical term is). I would think the lip on the inner opening would do that.
              you can use the stock bar on your 02, i've been using one for years on my 01
              fits perfectly - even with the mushrooms on the early cars
                Since this thread has been pretty busy, figured I'd ask if anyone recognizes what bar I have. Always assumed it was an early Mason/Rogue but cannot find any pics of one like this anywhere.
                Detectives what say you??​
                  Never have I seen that one, on a side note I received my RE bar yesterday, I'll have to send it back. One plate was bent badly and the other side is twisted a few degrees off from the other.
                  The D.S lines up but the P.S isn't close, the plate isn't on the same "plane" as the other, it's like it's rotated 5Β° off.
                  You can see the issue on the vehicle and when I set the bar on a flat surface you can see one plate is offset from the other.
                  I was told to try and install it and if doesn't work send it back, I can't even install this as one side doesn't line up for shit.
                  Click image for larger version  Name:	20260205_173916.jpg Views:	0 Size:	31.7 KB ID:	342711 Click image for larger version  Name:	20260205_173901.jpg Views:	0 Size:	32.9 KB ID:	342712 Click image for larger version  Name:	20260205_211213.jpg Views:	0 Size:	65.9 KB ID:	342713 Click image for larger version  Name:	20260205_211101.jpg Views:	0 Size:	68.5 KB ID:	342714 Click image for larger version  Name:	20260205_205504.jpg Views:	0 Size:	169.2 KB ID:	342715 ​
                    Cubieman did you ever sort this out with Rogue? Saw your post so I didn't pull the trigger on one of these. I also just installed MCS 1WNR with GC Race plates, and I've got both pushed as far towards the engine as the holes will allow so I can minimize camber adjustment on the plate itself (hidden set screws that can make camber adjust a PITA).
                      They sent a new one out, it'll be here tomorrow, hopefully all is well!
                        Yes, this is a very early version RE bar. I was just chatting with Ben about this design a few weeks ago.
                          Cool. Please update if you're able to fit it without jacking up one side, etc!
