Anyway, back to more interesting things.
(Forking this off from this post in Bryson's build journal, to avoid clutter over there: https://nam3forum.com/forums/forum/m...909#post305909)
Was having trouble getting the CSL duct to fit, so I figured I would take the opportunity and fix my bumper fitment. Most of the foam on top of the carrier has been missing for as long as I can remember, so first order of business was to replace that.
I was too lazy to go out looking for a suitable material and the printer was already loaded with TPU, so I figured why not. Quickly designed some foam replacement pieces and printed them out. My recreation incorporates both the radius of the stock pieces and the draft on the top surface to butt the seal up against the rest of the front end assemblies:
First test fit:
First attempt was very close, just needed a couple tweaks to get the fit where I wanted it.
While V2 was printing, I prepped the carrier. Started by removing the old adhesive, which was as fun as it usually is. With all that mess gone, I gave the surface a quick scuff and mixed up some epoxy.
Bonding went smoothly. I even had some adhesive left over to form a bit of a fillet on the pieces. Hoping that helps make it a permanent repair:
Final touch was to add some Krytox to the surfaces that the bumper will slide over, in an attempt to avoid ripping these pieces out in the future.
Of course, I forgot to take pictures of everything reassembled, but trust me, it looks way better!
First test fit:
