    You can always get fancy with the siraya tech core line:
Name:	Screenshot 2025-08-05 at 3.15.50 PM.jpeg.png
      Why do you say?
        Why do you say?
        Allegedly the carbon stays on the inside, so you don’t run the risk of handling fibers after you print.
          Some updates from the recent track day:
          • Firewall plug survived!
            • I still measured 80C at the firewall even after a full 30 min session. Seems like PET-CF is more than adequate.
            • Intake is LOUD in the cabin with this printed version. Not complaining about that at all!
          • Frenkit/Ohio Performance Solutions dust boots also survived!
          • Car absolutely hated being driven hard at 95F ambient with the AC blasting.
            • We were allowed to run windows up cause of the heat (which was really nice, actually), but I had to forego the AC as the day went on.
            • Once ambient temps got to the high 80s, the coolant temps would climb after a few laps. AC off + shifting at 7k largely resolved the problem (but instigated lots of complaints from the driver).
          • E86 braces are awesome on track.
            • Grip increase is immediately obvious. Braces give you soo much more confidence. Ended up doing a bunch of AB testing because it was so entertaining to feel how different the car was to drive with and without them.
            • For reference, with the braces installed, I was able to take turn 8 at 105 mph (indicated) without any drama. I had to be pretty damn brave to get close to 100 with no braces.
          I really need to sit down and finish up the cabin air filter housing CAD so that I can finally call the E86 braces project finished...
            Nice to have more more voices on the benefits of front end triangulation, as I kind of felt like a shill when writing up my Slon front brace review. But, it just is transformative! It's not shilling if it's the real result!
              Ohh yeah, the improvement is very real. Everyone who's driven the car has immediately felt a difference.
              One of my friends who drove it on the street was at the track day and we swapped cars for a session. I made him do the AB test and he was amazed by how much better the car behaved in the corners.
              He brought his 981S on PS4Ss, so I drove that when we swapped. I was able to keep up with my non-braced M3 in the Porsche, but the braced car outpaced me.
              (I'm sure the 981 would absolutely destroy the M3 on proper tires, that thing is crazy fast)
              I have a bunch of data from the day that I still need to analyze. Will be interesting to see what the data says about braces vs no braces.
                Rough ballpark on cost to reproduce your E86 brace setup?
                Old, not obsolete.
                  Hmm, here are my guesstimates for just materials (not accounting for welding/machining/install labor, 3D printer cost, tools, etc.):
                  • E86 braces: $100
                  • Windshield mount CNC machining: $1000
                  • Laser cut parts: $150
                  • 3M adhesive: $100
                  • Filament for HVAC plastics: $200
                  • Fasteners: $100
                  So a total of roughly $1650 for parts. Let's say $2k all in with labor and random tools you might need to buy.
                  I'll add a detailed cost breakdown of what I paid for everything to the assembly/install document I'm drafting up. Should give people a good idea of what to expect.
                    2K is still much less than the Slon kit, and I must say it looks "factory" from your photos. Impressive. Most impressive.
                    D-O
                    Old, not obsolete.
                      D-O
                      Thank you! That really means a lot.
                      I've put a ton of thought and effort into making sure it doesn't look out of place, glad to hear it has paid off. Should be very hard to tell it's not stock, once I've smoothed out the strut tower brackets and painted everything black.
                        • E86 braces: $100
                        • 3M adhesive: $100
                        • Fasteners: $100
                        The windshield mount using forged carbon fiber would be about 1/2 the cost of the CNC part.
                          Yep! That's also an option.
                            Also, I feel like I should clarify this. I am in no way trying to compete with Slon or offer a cheaper version of their kit. Slon pioneered and tested this idea and should receive all the credit for it. I never would have started this project had I not driven a car with the Slon brace installed.
                            Mine and Slon's versions are simply optimizing for different things and both have their pros and cons. Mine is optimizing for max "factory-ness" (including the crash safety stuff) and for ease of removal to make engine work simple. Slon's is optimizing for stiffness of the part and minimal interference with the cabin air filter housing.
                            I would really only pick my version if you care about what I mentioned above our if you want a much more involved project
                              Finally sat down to finish the design for the firewall plug. As mentioned, the removable insert that provides tool clearance was the only part that still needed work. This is where the design is at:
Name:	Screenshot 2025-08-09 at 11.08.39 PM.png
Name:	Screenshot 2025-08-09 at 11.09.39 PM.png
                              Those two tabs house the magnets that hold it in place before the filter housing is fastened. I'm fairly confident they'll be strong enough to hold the part up, but I might have to tweak that part of the design a bit.
                              Currently printing out the insert to prototype with. I did a lot of guessing with the clearances needed so that it can pivot forward and out, so it will definitely need some testing.
                              As for the gaskets, I'm thinking of printing them out of this stuff: https://recreus.com/en-en/products/filaflex-82a
                              It's a bit firmer than I would like, but I really need something that can withstand the heat in the engine bay. Vicat softening temp for that stuff is 113 C, so it should be fine. If that doesn't work, I'll have to resort to printing out molds and casting some silicone gaskets.
                                Amazing work heinzboehmer
