Nice! I just want to buy E46 M3s and do this to them all day long.
Immaculate low mileage 2004 Silver Grey CSL Inspired Build
He is very experienced and I would highly recommend him. I am very particular, and he definitely shares my standard/attention to detail. He has done my X7, and my neighbor's GT-R in the past. As far as I know, he is mobile only. You can contact him HERE.Originally posted by Maxima SE View PostBeautiful car ! Love a clean SG.
Was the dent removal person well experienced? Is it a mobile only service or do they have a shop too? Looking to remove a few dings from my Z4
Spent the morning continuing on with the radio / audio components delete. I started with the trunk area and removed the SOS module, navigation, radio, HK amp, and mounting frame.
I bundled up all the wiring harnesses in a microfiber towel then wrapped it tightly with friction tape. The bundle fit nicely in a little nook. I will find a more legitimate wrapping solution at a later time
Everything back together neatly. I then removed the emergency m-mobility system.
Next up was the HK under-deck mounted subwoofer
In addition to removing the speakers, I also had planned on replacing the rear parcel shelf with the streamlined Euro version and new c-pillars. Although the c-pillar trim was not faded, the fabric had started peeling from the edges closest to the rear windscreen. First the rear seat backs were removed.
Rear bench removed
Side bolsters removed. Next up was the removal of the plastic through-loading cross member trim. The plastic rivets were 100% stuck, and I had to cut the heads off just to get the trim off.
I then removed the c-pillars, unbolted the seatbelts, removed the seatbelt cover outlet, latch systems, speaker covers, speakers, and speaker mounts. I did not photograph everything step by step, as I kind of got into a nice work groove and did not want to stop to take photos. Here is everything removed.
The new parcel shelf and c-pillars were treated with Carpro fabric coating to reduce UV fade. Some new vs old photos below
I wanted to keep the parcel shelf as sleek as possible. I purchased the latch delete plugs for the speaker grills to plug the hole.
I attempted to install these into my new euro parcel shelf, only to realize the new shelf uses the smaller speaker grills! Turns out I purchased these, ceramic coated them, and installed them into the speaker grill for absolutely no reason. Oh well, smaller speaker grills already purchased and awaiting shipment.
While the c-pillar lights were out, I swapped out the hideous blue wedge bulbs one of the previous owners installed. They were swapped out with Sylvania long life 194 bulbs. The blue ones went directly into the trash can.
Part # for the speaker grille blanks? Didn't know they had 'em!DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
BMW Part No. 51468243667 and 51468243668. Weirdly, one is 3-4x times the price vs the opposite side.Originally posted by Tbonem3 View PostPart # for the speaker grille blanks? Didn't know they had 'em!
This morning I continued on with the rear deck project. I remember seeing Tbonem3 build thread where he added acoustic mat to the holes in the rear deck. Great idea, so I stole it. Although I want to remove some of the weight from the car, I don't want it to sound stripped out and unfinished. I created some templates and cut the acoustic mat to shape.
Factory sound deadening foam removed
Templates cut and installed
I then test fit the new rear parcel shelf. I checked my work from the outside of the car and saw that the area between the rear windscreen and rear parcel shelf vented trim was dirty. I had to take out the sound insulation foam, then remove the vented trim. While the trim was out, I ceramic coated it with Carpro Dlux. It was incredibly time consuming but worthwhile due to it being exposed to UV constantly.
Window was deep cleaned
Everything reinstalled. Along the way, I broke some clips which will need to be replaced at a later date. For now, I will be leaving the headrests out as well. The headrest holes were plugged with a rubber BMW blind plug. Thank you to Casa de Mesa for the idea. I will update once the new speaker grills and replacement clips arrive.
Did you buy the Euro rear deck new or find it used? Think I might need one of those. I cannibalized my US one anyway for the BK rear deck harness mounts that I don't want anymore since I can just use a QFP for my occasional track days.
Don't forget you can get a slimmer carpet and larger tray for the driver side of the trunk since you deleted the nav stuff.
This makes sense, thanks for the heads up. When the new clips/speaker grills come, I will remove some of the acoustic mat over the oval shaped holes so that the air can properly move.Originally posted by Bry5on View PostLooks good, keep your ear out for buffeting with the windows cracked as the cabin vents are in the trunk and it looks like those holes are the air passages.
I purchased the Euro parcel shelf new from getBMWparts.com, BMW Part No. 51466955325Originally posted by repoman89 View PostDid you buy the Euro rear deck new or find it used? Think I might need one of those. I cannibalized my US one anyway for the BK rear deck harness mounts that I don't want anymore since I can just use a QFP for my occasional track days.
Thank you for the reminder on the carpet/tray. It is on my to do list, the back burner at the moment. Trunk space is a low priority right now.Last edited by Avedis; 06-14-2023, 06:18 AM.
New through-loading cross member trim, seatbelt outlet guides, retaining clips and speaker grills came in. I ceramic coated all the parts prior to installation. The euro parcel shelf project is complete. Looks amazing. In person it looks so fresh and so minimalist.
Some random photos from a costal cruise this week
- Likes 5
To me, the windshield wipers have always stood out and cluttered the front end, which is otherwise near perfection. At this point in its life, this car is a once a month, perfect weather, SoCal coastal/canyon run type of treat.
I have a long term plan of deleting the windshield wiper motor, arms, and plugging the holes. Until then I still wanted to get rid of the wipers. I picked up a set of No-Coast engineering threaded windshield wiper delete caps. They are 3D printed and are model/chassis specific.
First I removed the wipers/arms
Then taped everything off and polished the windshield
Windshield was then coated with Gyeon View coating
3D printed texture was a bit too unrefined for my liking. I put them on the end of a drill and sanded them down. Texture didn't turn out perfect, but far better than how they looked when I received them. This is the before photo. After texture can be seen in installed photos.
Ceramic coated the windshield cowl with CarPro Dlux, then installed the wiper delete caps. Final look, much cleaner.
Acetone will help with the finish on those 3d printed parts. Lots of videos/guides online on this in case you want to mess with it some more.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Wiper delete.
Dawg.
That's next level lol.2004 BMW ///M3 Carbon Black/Cinnamon 6MT Dinan S2 FBO NA Build
2005 BMW ///M3 Interlagos Blue/Black 6MT Dinan S3-R+
2019 VW GSW S 4MO Platinum Grey/Black6MT Daily
- Likes 4
Yeah that would not be legal in my country hahaOriginally posted by Sharocks View PostWiper delete.
Dawg.
That's next level lol.2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
