Clutch switch
    Originally posted by M3LSB.Gab View Post
    I bought a SMG ZCP converted to 6 speed but I have similar issue with OG. This is the clutch switch I have on the car.
    You’ll need to source a used brown or green one, those are not available new, I believe that is the consensus.
    The black ones do not work, as they switch ground instead of power, they are intended for the non M cars.
    Brown = USA, allows you to retain clutch in to start safety (4th pin)
    Green = Euro, can start car without touching clutch, no 4th pin, need to code EWS to Euro.
    Both work, also with cruise control (some misinformation above) I have green on my personal car.
    You can also source them from E39 M5’s, maybe there are cheap M3/M5 pedal assemblies on ebay with the switches still installed.
      I have green installed on my Z4M and it works too, as mentioned, I had to code the car to Euro spec
      I still have my original brown switch which I thought was broken but it was not. ended up being a wiring issue.
        Green Euro switches are still available new. Additionally, from what I have heard, the new black M3 switches (ending in 700) work as well.
        The only switch now that will not work in our cars are the non-M switches (ending in 898).
          this was false internet information, I actually got TWO of the black flavor, and they did not work.
          Brown - good
          green - good if coded
          black - not good, the issue with this is the cruise control, it does not work.
            I bought the black clutch switch from bmw, that replace the NLA brown one. Will receive it in 3-4 days. Will keep you updated. Anybody has an image/diagramm on how properly connect it ?
            • 61319122700
            Instagram : @gc.m3zcp
            2023 M3C Xdrive British Racing Green
            2009 M3 Alpine White DCT
            2005 M3 ZCP Slicktop Alpine White 6 speed
              Brown - good
              When did you buy these two switches?
                Back in 2022 I think. At the time the browns where already NLA and green was still available from FCP.
