Clutch switch
    Originally posted by M3LSB.Gab View Post
    I bought a SMG ZCP converted to 6 speed but I have similar issue with OG. This is the clutch switch I have on the car.
    You’ll need to source a used brown or green one, those are not available new, I believe that is the consensus.
    The black ones do not work, as they switch ground instead of power, they are intended for the non M cars.
    Brown = USA, allows you to retain clutch in to start safety (4th pin)
    Green = Euro, can start car without touching clutch, no 4th pin, need to code EWS to Euro.
    Both work, also with cruise control (some misinformation above) I have green on my personal car.
    You can also source them from E39 M5’s, maybe there are cheap M3/M5 pedal assemblies on ebay with the switches still installed.
      I have green installed on my Z4M and it works too, as mentioned, I had to code the car to Euro spec
      I still have my original brown switch which I thought was broken but it was not. ended up being a wiring issue.
        Green Euro switches are still available new. Additionally, from what I have heard, the new black M3 switches (ending in 700) work as well.
        The only switch now that will not work in our cars are the non-M switches (ending in 898).
          this was false internet information, I actually got TWO of the black flavor, and they did not work.
          Brown - good
          green - good if coded
          black - not good, the issue with this is the cruise control, it does not work.
            I bought the black clutch switch from bmw, that replace the NLA brown one. Will receive it in 3-4 days. Will keep you updated. Anybody has an image/diagramm on how properly connect it ?
            • 61319122700
            Instagram : @gc.m3zcp
            2023 M3C Xdrive British Racing Green
            2009 M3 Alpine White DCT
            2005 M3 ZCP Slicktop Alpine White 6 speed
              Brown - good
              When did you buy these two switches?
                Back in 2022 I think. At the time the browns where already NLA and green was still available from FCP.
                  I replaced the clutch switch with the new black one that replaces the NLA brown one (PN 61319122700 - written 314 on it). The car idles better and no longer stall at stop, but it is not perfect. Maybe i'm too used to newer bmws now ^^. The one that was installed had 180804 written on it.
                    I replaced the clutch switch with the new black one that replaces the NLA brown one (PN 61319122700 - wrote 314 on it). The car idles better and no longer stall at stop, but it is not perfect. Maybe i'm too used to newer bmws now ^^. The one that was installed had 180804 written on it.
                    did you install the gear position sensor on your car?
                      I just changed the clutch switch. Not sure about the gear position sensor if it was installed with the manual swap or not. It is a zcp also.
                        I would check to see if you have a GPS installed and if not, reference THIS thread to see if this line of code was changed.
                          What do you mean by "it is not perfect"? What issue are you still having?
