I would love to use the tool but sadly my ecu is encrypted and bmwflasher cant pull a usable file from it.
MSS5x Binary Modification Tool Update
I think it was to protect IP, not to stop an individual owner from tweaking it.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Hi Martyn, any plans (if feasible) to tweak MK20 DSC through your tool in the future? Buildjournal offers a "sport mode" tune for MK20 cars which reduces the intervention threshold to somewhat mimic Sport mode on MK60. Thanks!Originally posted by Martyn View PostShoot me another email, I get pretty snowed down when I’m super busy so things slip through the net.Last edited by lemoose; 11-19-2020, 07:44 PM.2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
Thanks. I believe they flashed it with MSS. When I tried, it was flashed through BMWFlash. So regardless of me using MSS to get the file, it still won’t work?Originally posted by Martyn View PostSounds like they flashed your DME with a different software version so your license will no longer work.
You have confused MSS54 (or HP) software version on the ECU with WHICH software was used to pull/push the data to/from the ECU. The ECU has software on it, essentially the "OS" and the "Tune" which are related to each other as each OS's Tune has the tune data in a different order, and sometimes sizes (bytes vs words). So if the ECU OS (ie 1301, 1401 etc change, Martyns tool will think it is another ECU, thus not thinking that ECU is licensed to work with his software. I don't remember what his software checks, whether its VIN/Software version, as some info is on the ECU 2x (master/ slave) I can't recommend a way to get around his software, which I did find when I was flashing different stuff all the time for my E30 swap, but using the same ECU itself, until I figured out how to use TunerPro/Hex Editing and have more control.Originally posted by S3diment View Post
Does that make sense?Last edited by R3Z3N; 08-15-2021, 10:54 AM.
