Originally posted by mrgizmo04
RACP Failure After Plates
you cant do the plates with the subframe in the way. You might as well drop it and inspect the entire area to be sure what needs to be done. The vincebar is all in the trunk and cabin, but it would definitely be easier with the subframe out of the way for drilling up through from the bottom.Originally posted by freezingair View Post
Hi is it the same for the Vincebar installation? We don't need to drop the subframe for that ? In this case if I still want to do lower racp plate, it feels I need to have two quotes of the job. One Vincebar and one lower plate. If racp does not have crack, can I just install Vincebar?
I see, thanks. got it so it is totally possible to install the Vincebar or cmp bar without removing the subframe. I may do them in two steps first install lower plate and then save money for installong the top bar later. Does it waste labor time by your experience, thanks.Originally posted by Kcalhoun27 View Post
Cant speak to the CMP, i did the vincebar myself so thats what i know about. I dont think youll save much labor or money doing them seperately. The plates will require removing the subframe and the vincebar will be much easier with it removed. the amount of work that goes into each invidual job is quite a lot, adding them together is going to be advantageous in the long run.Originally posted by freezingair View Post
its a big job but once its done you should be good to go. As so many have said before, ‘buy once, cry once’
Lovely quality but i feel the shifting now on the SMG is so much harsher. I'll switchback to OE Subframe bushes in he future if I can be bothered.Originally posted by pawa_k2001 View PostOff topic but regarding CMP Solid Subframe Raising Bushings. Anyone run them? Are the worth it? How is the NVH?
How much was that just out of curiosity?Originally posted by Gt4 View PostIf anybody needs to replace the entire RACP on his E46 M3 soon, there is only ONE new panel left at BMW Germany. That’s what my dealer told me this morning when I pick up mine:
Last fall, dealer quoted me at $2500CAD+tx. Finally, I ordered it 3 weeks ago thru same dealer at $1500CAD+tx!! hahaOriginally posted by Nate047 View Post
Just got a new welder, first time I will try it will be on this RACP job!Last edited by Gt4; 02-23-2023, 09:08 AM.Send me a pm for Gt4 Composites carbon fiber CSL parts
- Likes 5
How bad is the floor that your decided on the entire panel??Originally posted by Gt4 View Post
YOU always go full out with your parts and upgrades! BRAVO!
Really bad!!!Originally posted by pawelgawel View Post
Long story short, previous owner went to a local shop for an inspection/quote to fix the RACP and the shop quoted him 10000$ CAD to replace the RACP and offered to buy the car for 8000$ CAD instead!! His friend than contacted me and offered me the car cause he knew I was able to fix it myself and that I would do a complete restauration of the car.
Car is a 2001/02 HEA package so one of the first E46 M3 in Canada.
The car previously had Turner plates welded. Than, when spot weld start to pop, someone tought it would be a good idea to fix it with undercoating… So problem got worst and it look like this now:Send me a pm for Gt4 Composites carbon fiber CSL parts
Ah they probably used regular undercoating instead of the structural stuff. Easy mistake to make.Originally posted by Gt4 View PostThan, when spot weld start to pop, someone tought it would be a good idea to fix it with undercoating…2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I mean they shoot rattle can undercoating, just to hide or seal the panel splitting probably when it first start!Originally posted by heinzboehmer View Post
Ah they probably used regular undercoating instead of the structural stuff. Easy mistake to make.Send me a pm for Gt4 Composites carbon fiber CSL parts
Replacing the RACP shouldn’t be that bad. Let say I did bigger projects in the past. Check this thread to see some previous build I made. Doing RACP is going to be easier than stitch welding a complete race car!!!Originally posted by pawelgawel View Post
LOL!!
Thats a project and a half.. God Speed with You on that one..
https://nam3forum.com/forums/forum/s...us-your-builds
Wow! I'm interested to see how much movement on the diff when moving from stop forward and reverse in current condition, in videoOriginally posted by Gt4 View Post
Really bad!!!
