Originally posted by t3ddftw View PostHey guys,
Can anyone with the "IHKA dying" bug please install this firmware? https://t3ddftw.s3.us-east-2.amazona...bus_1_1_15.hex
It is experimental, so if something goes wrong here is 1.1.14: https://t3ddftw.s3.us-east-2.amazona...bus_1_1_14.hex
It seemed to work fine on my 2006 E46. Here's the changelog:
* Complete rework of the lighting activation functionality. Lighting I/O status is now only requested when the dimmer state changes OR if we have gone more than 20 seconds without seeing the I/O status. This is different than before as I used to request I/O status every time the dimmer status was seen, but requesting the I/O status resulted in another dimmer status update (which caused an avalanche of messages). Further, code was added (kindly by another contributor to the project) to identify the particular LCM/LSZ variant and send the appropriate values in the bulb activation request.
* A bug that caused the E46/Z4 IKE to dim out when using turn signals during the day has been resolved
* Cyrillic character transliteration has been added (by another contributor). This also includes the angled quotation marks that many iPhone's like to use (which should fix how your iPhone's name is displayed on screen).
* The DAC is now powered down at boot, then it is powered back on shortly after. This should hopefully clear the condition that causes the I-Bus impulses to be audible at every volume level.
* The I-Bus message queue is now capable of firing off more than one message at a time (which was a bug).
Thanks!
-Ted
Thanks!
Originally posted by BubbaTree View Post
Ted, I got the 1_1_15.hex installed, yeah, I know you're amazed -so am I! Anyway, I've had no issues so far, but temps are only about 106 so far. I'll report back in about a week.
Thanks!
106? I miss those hot southwest summer days. Ohio weather isn't for me...
I knew you could figure it out! Hopefully you installed the version from this thread which has working one touch blinkers?
Yes, it's 1_1_15 picked up here at post 443. One touch blinkers work right, A/C doesn't seem to be haunted anymore. I do have some funky things going on with my Bluetooth hearing aids and iPhone, but that's not an issue just now, and probably has nothing to do with BlueBus.
-Ted
Originally posted by Orphee View PostSniff... don't know were to buy it...
Found it!
Hello Ted !
Since the new firmware 1.1.15, names of the songs which have some special caracters appears badly.
Here is an example, " is replaced by \22
I use an iPhone 11 Pro
Not an issue for me but just to let you know
Also, I've had the case of my right blinker didn't stop blinking, I had to manually go left and right with the blinkers command to stop it.
This, I don't know if it is specific with firmware 1.1.15.
Doudou
Doudou
Originally posted by calmelb View Post
I have also had that issue, I found it happen if I suddenly changed indicator (eg from right to left) but couldn't accurately reproduce it or get logs though
-Ted
