Originally posted by Obioban
Triangular Carbon Reinforcement strut bar kit - New Development
Yep, very happy that they're producing these parts for our cars, but this looks to be a pretty 'involved' design...and I'm sure that it will be priced accordingly. I think that it would've been a bit on the pricey side even in the best of times, but this economy (especially) sucks right now for this kinda stuff! Still following though...Originally posted by bjz! View PostPrice will be crazy.
ANY of the struts, which fix only 2 turrets - waste of money. they will make absalutely the same result as oem strut brace, even if you made it from carbon fiber, or gold or even platinum.Originally posted by 01SG View PostI thought strut bars hardly did anything anyway? I also cannot see how a weight difference will matter. An aluminum Mason is 3.5 whole pounds.
The Karb strut bar seems like a big waste as well. I do not see any benefit to carbon fiber in this application. It is just burning money-unless this is cheaper than Rogue/Mason, which I doubt.
chassis with OEM strut brace vs no brace at all showing 1.5% difference in chassis torsional rigidity.
fundamental difference that our reinforcement has third fixing point on the bulkhead. this is the game changer and moves our solution to an absolutely different level.
i'll write this again, 1.5% on any usual strut brace VS 18% on our triangle design. lets continue from here
Me too, but....Originally posted by stash1 View Post
I took out the HVAC filter housing one time (I already removed the hood insulation too) , and I couldn't tell whatsoever that there was any more noise or difference.Originally posted by Casa de Mesa View Post
So just thought of another benefit to this setup - MORE INDUCTION NOISE!!!!DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Way to burst my bubble...Originally posted by Tbonem3 View Post
I drove around for a few days with the housing removed and no hood insulation. There is definitely a difference with the stock intake. Probably not as noticeable with a CSL intake.Originally posted by Tbonem3 View Post
Regarding triangulation, isn't the strut towers already tied to the firewall through the drug bins? The Z4 Ms doesn't have the bins so they get a triangular brace. Anyways, this strut bar looks way more robust. I always resisted forking out big money for a strut bar because none of them attach to the firewall.2001 TiAG M3 - 6mt Coupe, Anthracite Impuse - SOLD
Sounds nice. Doubt most people will go all the way and actually install this. Can you even go back to stock?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
From messing around with the leftover epoxy from my vincebar install, I've found that a heat gun makes it pretty brittle. So some heat and prying are probably all you need to get the piece that attaches to the firewall off.Originally posted by Tbonem3 View PostSounds nice. Doubt most people will go all the way and actually install this. Can you even go back to stock?
It's possible that it doesn't extend out into the engine bay anyway, so maybe the stock pieces fit back in with it still attached.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
This was my thought too. However, resale of the bar would be a bit of a challenge unless Slon offers just the mounting block separately.Originally posted by heinzboehmer View Post
Regardless, I'm still intrigued by this.
By the way, in the repair/replacement instructions for the BMW carbon roof, they tell
you to heat/bake the roof until the glue weakens to remove the old roof. So it's entirely possible that the method you suggested would remove that block. Whether or not the resins in the carbon block would be any good after that (reusable) I have not a clue...Build thread: Topaz Blue to Shark Blue
