Turner Motorsport CSL Airbox
I took my unfiltered section off and adjusted the mounts to the horseshoe bracket. I was able to get the back of the box just a little bit lower, only enough for the cabin filter housing to just *barely* clear it for the most part, but I believe there are points where it is still touching, and, with the engine running there's no question they absolutely will rub together and cause further damage. Below are photos of the damage that has accrued so far, showing where it rubs on the cabin filter housing, and photos of lack of clearance after adjustment.
Also noticed when re-attaching the unfiltered section that the front locating dowel that secures the front bottom of the box to the unfiltered section has fallen out. That's not good. Pic attached.
Was able to get more clearance for the strut bar, though, maybe it's enough. Pic attached.
Will be reaching out to Turner tomorrow, hopefully they'll be good and helpful about it. They've been good to work with so far!
In the event that Turner tells me to GTFO, is the damage that has been done repairable? To what extent, and will it be expensive?5 PhotosLast edited by ATB88; 06-15-2020, 04:59 PM.
I guess we asked for it being in the first batch. I just was expecting that turner would run some actually mounting tests... and being honest, we waited for it since December, so enough time for testing...
Can somebody measure those upper mounting standoffs (on the right of photo #4 above)? How tall they are in mm?
Yeah, I figured that being in the first wave of boxes means possibility of fitment issues. But, because of that, I also expect Turner to do the right thing if the issues that I'm experiencing are their fault and not simply due to my own error.Originally posted by rbg View PostI guess we asked for it being in the first batch. I just was expecting that turner would run some actually mounting tests... and being honest, we waited for it since December, so enough time for testing...
It sounds, so far, like I am the only one whose box has suffered damage by rubbing against the cabin filter housing?Last edited by ATB88; 06-15-2020, 05:12 PM.
Looks like two of you so far...Originally posted by jk715 View PostI wouldn't be surprised if they do a V2 redesign to fix the rubbing in the back with the cabin filter housing. Definitely not enough clearance in the rear. I'm taking it all apart to bend the bottom brackets down a 1/2 inch.
I guess he didn't make it clear to me whether or not his has been damaged or if he's just noticed how poor the clearance is and wants to be pro-activeOriginally posted by rbg View Post
I think that dremelling/grinding down that area of the filter housing to give enough clearance is a fix that I could live with, but, the damage already done to the box is kind of upsetting 😒
Then you’re might have water running down the airbox when it rains.Originally posted by ATB88 View Post
I think that dremelling/grinding down that area of the filter housing to give enough clearance is a fix that I could live with, but, the damage already done to the box is kind of upsetting 😒06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
Budget CSL MAP Conversion
Originally posted by TosM3 View PostDoes anyone have a DYI to install the intake
https://thebuildjournal.com/diy/turn...ll-diy-e46-m3/
Looks like buildjournal is showing a 54 whp gain and a 17 wtq gain. Cost out the door 2500 with everything they needed. Guess if you have the later model ecu you will save some cash.
Am i nuts to second guess that they are pulling 30 whp just from their tune? They are getting 35 with the eventuri. Seems kinda nuts for just a tune.
https://thebuildjournal.com/reviews/...-dyno-results/
Doesn’t sound extremely high. No cats free up a lot of HP specially when a tune is added.Originally posted by Tones View Post
