Originally posted by George Hill
Unlimited Money-What is your first move?
Originally posted by George Hill View PostLooks like a MK20 car.
Do you have anymore info on this setup, would love to see it.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Originally posted by ZiMMie View PostUnderstood. I would have said/want the same thing 3yrs ago. Maxecu is far superior than the stock ECU or any other ECU when it comes BMW CAN Integration. Not to mention their amazing customer services than can write literally a CAN function if its not available.
Hopefully ill get to build my dream in the e46 in the next few year it will definitely be running MaxECU not that dinosaur brick .
And along those lines, my E46 will likely start off with an AiM dash setup to integrate with the MSS65 CAN... which will be how I get around the chassis integration issue until we work out a permanent street car solution that is being planned.
Originally posted by 01SG View PostI stand corrected. That's pretty awesome. How do these swaps complicate routine maintenance though? Jay Leno had a 1-series with a s65 swap on. The guy said he had to drop the front sub-frame just to change the plugs.
*Actually I just looked it up. Yes, the strut tower and firewall is the same between E82/E9x... and E84
Originally posted by heinzboehmer View PostHmm, the brake fluid reservoir makes me think it's an MK60.
'00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT (SOLD), '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Japan Rot 325iT
I'm not arguing that a MaxxECU isn't a superior ECU hardware and flexibility wise. BUT I will say that it is my opinion that a layman/end user (and not a tuner with unlimited time) will NEVER get the drivability as good as a stock DME file. With that said I'm putting a Maxx on my turbo M52, so no hate there, but I just don't think the all around drivability will be as good as BMWs file. Plus now you have to package it in the car and integrate into the wiring harness, not the end of the world but certainly not as easy as most stock DMEs. Also some of the cars need to be emissions complaint and you can't do that with an aftermarket ECU.
as for drivability, If you were to utilizes all the input individual cylinder EGT, Lamba, Etc i bet you can get running better than STOCK this will be for MSS6x or older ecus.
Now back to the main topic, people are quick to say swap s65/s85 in an e46. Goodbye to chassis/vehicle dynamics as you will always have to comprimise fo
Tires,Brakes,suspension etc. The s54 is perfect for the E46. it just need less weight.
If money wasn't an issue and i have to stick to an e46 chassis, full carbon chassis with a stock CSL Power level 360PS.
Perfect chassis for an S85 will be any of the E8x/E9x chassis not an e46.
^that’s why this was my pick:
Originally posted by Obioban View PostThe e46 carbon monocoque SLON is working on.
Pretty sure that one is otherwise going to be outside of my budget.
Maybe? IDK, I've never seen an S65 1M, but IIRC the engine bay is exactly the same as an E9x (same part numbers for the strut towers) so maybe there was more to his issue?
Maybe MK60 in MK20 location then, hard to tell, the MK20 has all (6) brake lines on one side and that looks like maybe just (4). If that's the case I wonder if the DSC works or just ABS... or does it use the E39 Bosch ABS with a pre-charge pump?
Originally posted by Obioban View Post^that’s why this was my pick:
… Though I don’t think the s85 makes a ton of sense in the e90, since the e90 chassis is only 72 pounds later than the e60 chassis, comparing like for like (as in, same engine/trans/idrive/sunroom between e90 and e60).
Originally posted by Slideways View PostS65 1M conversion details if you're interested'00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT (SOLD), '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Japan Rot 325iT
we have swapped 2 cars and this swap goes like oem.
more interesting facts:
e92 m3 front subframe has 8 mounting points over any usual non M subframe with 6 mounting points. so zero e82 cars with 8 point subframe from factory. and you can take m3 subframe and simply install it on e82 chassis, cause it has those 2 additional threads already, on all chassis.
you can even take stainless steel fuel line from e92 m3 and fit it to e82 chassis - you only need to cut and weld it under the rear passenger floor.
so nice story about plugs change .
Originally posted by Slonik View Poste82 is so similar to e92, that even front turrets, front frame rails etc, has the same part numbers (its a one car with 2 length options and different exterior design). two chassis differs in the rear passenger floor - e82 shorter on 10cm.
so nice story about plugs change .'00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT (SOLD), '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Japan Rot 325iT
Given all that, pretty crazy the e92 M3 is 500-600 lb heavier than a 128i, carbon roof, plastic fenders, and all.
more powerful engine in most cases pull a lot of other heavier and beefy things - dct, clutch, driveshaft, differential, etc even brakes usually larger, even more options inside the cabin.
so comparison with 128i not truly correct.
same front structure of the chassis (same part numbers), so i'd guess maybe not like e82 vs e92, but also possible.'00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT (SOLD), '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Japan Rot 325iT
with the similar config (s65+dct) - about 80kg difference between cars.
