e46 M3 Community-designed CAD files Master List
    That wouldn't be a great candidate for 3d printing. It looks like a simple cut extrusion? Might search on summit or jegs for hot rod door seals and look for something similar.
    2003.5 SG/Grey
      Anyone have the ZHP/CSL brackets to run the larger front rotors in CAD
        Anyone have a scan of a CSL snorkel handy? I keep cutting up Haimus snorkels and it’s getting expensive…
        David
          David
          I don't have one, but it would be very useful. It has occurred to me previously that it would be a fairly simple (in comparison to Bryson's knuckle or Heinz's front strut brace) project to recreate the original snorkel with a 3D printed body, the stock actuator and potentiometer, plus some hardware to have a functioning snorkel and flap for less than crazy money.
          Build Thread:
            I can have a Karbonius snorkel scanned but I like the dexterity of the OEM/Haimus one. I might go take both to a professional scanner tomorrow.
              Yeah I have a Haimus one for pretty much the same reason.
              Build Thread:
                David
                I have a scan of a Karbonius one that I can dig up for you tomorrow, if it's useful. I think the scan is dimensionally accurate, but I would for sure do some measurement validation against your own snorkel before trusting it. These consumer grade scanners really don't like thin walled objects.
                Also, just FYI, the Karb and Haimus snorkels are not exact reproductions of the stock snorkel. They both seem to be clocked slightly differently, which puts the mouth of the snorkel a good 20mm off of where the stock one is (and of course they're both off in different directions).
                  How delightful 🙃 I'll be interested to see how I get on fitting it to Bryson's intake duct
                  Build Thread:
                    Ha, that's exactly how we found out the geometries were different. At first I thought something was wrong with my car, but nope, turns out the aftermarket snorkels are off.
                      That would be great. I’ll have the Haimus snorkel scanned and we can triangulate a better fitting aftermarket snorkel!
                        Hmm, this scan is a little more noisy than I remember, but you should still be able to pull out the important geometry from it: https://s.digital3dcloud.com/space/f...8-fad9ae1ec8fa
                          There are two duct files now (three if you count the non-m ZHP part) - one for the factory snorkel and one for the karb snorkel. So far they seem to be fitting well for each respective config. The karb snorkel is a bit taller, so a few millimeters more of it has to be chopped off due to the z-height limitation of the bambu P and C series printers. It shouldn’t affect operation fortunately.
                            Made a little file for a cup holder, wallet holder, and fob holder (valvetronic) for the vorsteiner CSL console storage tray. Just have it double sided taped down
                            Mocked up a quick cup holder for my vorsteiner csl style center console. i printed in PETG-CF, currently printing v2 for the first time for time will tell if it works or it good, still a work in progress and will upload my final version once it is ready.Added a v2.1, this makes the base cup holder hole larger (78mm from ~72mm on the v2), and i also added a file for an adapter piece that goes 78 -> 68 mm, for use with smaller diameter drinks. Also changed the shape of the cutouts for the wallet/fob holder to be a bit nicer to touch/feel.
ID:	316240Click image for larger version
ID:	316241Click image for larger version
                              Love it
                                updated this with some minor changes. Made the wallet and fob holder 'pill' shaped, with chamfer/fillets on the interior edges, so things can slide in and out more easily. Also made the overall cup size bigger on the main print, but included an adapter piece which has clearance for a difference of 0.5mm in diameter, so it fits snugly with no need for key/lock mechanism. I'm probably done with this file for now as its pretty functional for it's purpose.
