I have the 701 euro clutch switch installed in my car without a GPS and wired and coded correctly but cruise control doesn't work. The green light does light up but after that it won't work. The car itself works flawlessly with no stalling issues but no cruise control.
SMG to 6MT Conversion
Originally posted by PipeUy View PostI have the 701 euro clutch switch installed in my car without a GPS and wired and coded correctly but cruise control doesn't work. The green light does light up but after that it won't work. The car itself works flawlessly with no stalling issues but no cruise control.
I have a mss54hp dme, and did the following coding:
Assuming you're on the latest software (probably are if it was flashed with a manual tune relatively recently), then 01 to 02 at 0x802a, FFFF at 0x5952, and A0 at 0x88A2.
For what it's worth, I have the 61318363710 cruise/clutch switch wired to DME pin 20 at connector x60002, no clutch start switch, no gps, and my cruise works normally. What coding did you do?
Originally posted by wsybert View Post
I just bought one from eEuroparts. Had to call to make sure, but it got the 61319122700 part. Sales guy had to look it up to make sure it was what was on the shelf.
Anyone need a 35426876898 clutch switch? Make you a hell of a deal!Last edited by M3llowM3; 03-12-2021, 03:30 PM.
Originally posted by terra View PostAnyone know how to open these switches up and expose the board? I imagine it would be as simple as moving a bridge to change the output from ground to +12v'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Well in the absence of the proper switch, I think the only real options are to retrofit the old style switches (+/- start lock delete), use the euro switch and delete the start lock, or do a hybrid setup with the euro switch for cruise and the old switch for start lock. I suppose one could also use the non-M switch for the start lock and the old switch for cruise.
terra I thought I recalled awhile back you or someone else mentioned coding the DME as if it was a Z3M and then not using a GPS, that would allow the non-m switch to work? Is that a possibility or am I completing off?'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Originally posted by terra View PostNo, the Z3m coding lets you eliminate the gear recognition sensor and wire the clutch switch directly to the dme. The dme still expects the signal to be pulled high (the non-M pulls it low).'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Hoping someone can confirm for me whether this will work. But Rather then hooking everything back up. Could I remove the SMG slave cylinder and install the clutch pedal with manual cylinder. Then bleed the system with a power bleeder. Then be able to release the clutch to spin the driveshaft with the clutch pedal?2003.5 Titanium Silver / Black 6M/T (Gone)
Originally posted by SandeepM3 View PostHoping someone can confirm for me whether this will work. But Rather then hooking everything back up. Could I remove the SMG slave cylinder and install the clutch pedal with manual cylinder. Then bleed the system with a power bleeder. Then be able to release the clutch to spin the driveshaft with the clutch pedal?
Other option: connect your new master output pipe to the stock SMG slave input port instead. Then use the pedal to disengage the clutch.Last edited by sapote; 04-09-2021, 11:22 PM.
Yeah just put something through the hole in the selector rod joint and pull/push it into neutral2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
