Originally posted by liam821
Originally posted by bassel_sy View Post
it appears RR is the way to go.
Yep, totally - at least for the rear. Well worth the extra $50 or whatever it costs. I shouldn't/can't blame CM for the whole brake line fiasco as they don't manufacture them in-house and the other one was perfect, and I should have been more careful and checked the threads beforehand.- 2006 AW/IR Manual
- Karbonius Race / Alpha- N
- Supersprint
- KW V3
- 996 Brembo
- ZCP / PSS
Originally posted by WOLFN8TR View Post2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
Seems like the general consensus is that the RR brackets are the way to go.... But from what I understand- both require some grinding? So the main advantage of RR is just to get taller rear pads?
Also, I was curious if anyone knows what paint code the blue part of the BMW roundel is? I am thinking about seeing if my local auto body store can mix me up some high temp in that color....
I am TiAg on graphite VMR 710’s 19”, 8.5” fronts ET35 , 9.5 rears ET22. Also going to be interested to see if I need any spacers
There are lots of affordable blasting options out there - even from Harbor Freight - that provide excellent results. Of course if you have the money to spend, a proper blast cabinet is the ideal solution.
Originally posted by M Coupe View PostBest method and tool to get is a sand blaster tool with aluminum oxide media. While sandpaper may work, it fails in several areas. It doesn't give the substrate the proper 'tooth' to bite into and you can't get into all the nooks and crannies with sandpaper.
Originally posted by duracellttu View PostAnybody know the best way to remove powder coat? My metal pins weren’t masked off and I want to remove it before installing.
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
Originally posted by M Coupe View PostVery thorough and well photographed DIY Porsche BBK ugrade sir. Itching to save up to put together my own creation!
Originally posted by pawa_k2001 View PostWhat pad combine have people found to work best? ATE, Akebono, or is there another pad thats recommended?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Best for what? Best street pad would be stock porsche textars imo.
It does this about 90% of the time.
One of the biggest pluses of this conversion is how easy pad changes are, so I would get Textar for street, then a dedicated track pad.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by HDdave View PostSeems like the general consensus is that the RR brackets are the way to go.... But from what I understand- both require some grinding? So the main advantage of RR is just to get taller rear pads?
I am TiAg on graphite VMR 710’s 19”, 8.5” fronts ET35 , 9.5 rears ET22. Also going to be interested to see if I need any spacers- 2006 AW/IR Manual
- Supersprint
- KW V3
- 996 Brembo
- ZCP / PSS
