Originally posted by duracellttu
Originally posted by Thonas View PostThanks! Did you get new front ones or reuse the ones that were with the calipers you used?2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
Originally posted by Thonas View PostDid you guys install the brake shims below or can you leave them off?TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
I said screw it on the stickers but they really do reduce the oscillations. That's what causes the noises in brakes. When you push the pad to the rotor, it'll create multiple harmonics and it'll be one of those you hear. The pads are dampened with the idea that it'll help deaden certain frequencies out. The sticker dampener is probably the biggest key to reducing noise along with grease on the sliding points. Sometimes it can literally be as simple as a spring being uneven on the pads. Once I remember to download it, I'll post the Porsche TI on brake noises. It applies to all vehicles and explains it in depth better than I could everThis is my Unbuild Journal and why we need an oil thread
Originally posted by fullyflaredd View PostAnyone know if the PFC 2 piece rotors work with the 996 kit?This is my Unbuild Journal and why we need an oil thread
Originally posted by fullyflaredd View PostAnyone know if the PFC 2 piece rotors work with the 996 kit?'03.5 M3 SMG Coupe - Jet Black / Black
If the millimeters are the same, I don't see why they wouldn't. Rotors are basically all the same shape. They sort of have to be. The calipers don't move and the inner portion of the rotor doesn't. It'd take a lot of unnecessary material to make them touch. Remember these calipers are just Brembos on a budget. I can imagine PFC wouldn't design something that wouldn't clear Brembo upgrades. Just like rotors, calipers have to generally be designed the same way.
You might get away with it using the pad that has a 5mm shorter anulus. Look at the original post for the part numbers. I remember the PFC 2-piece requiring a specific pad shape that was PFC-only to clear the 2-piece hardware.Last edited by fullyflaredd; 01-04-2021, 04:06 AM.
