    I ordered them from FCP a month or so ago. Checking now they are, in fact, no longer listed on FCP. bummer......
      Looks like they'll still be offering warranty on them if you bought them in time though: https://rennlist.com/forums/racing-a...l#post17192852
        I reached out the them to ask this and will update with the response but the link to rennlist looks promising.
          Yes warranty is still being offered, but you have to get different pads since it’s no longer being offered. And they don’t have equivalent pad list available. Last year I purchased DTC60/70 from them for this application now they don’t even carry those for Porsche only for BMW that’s why I wanted to go with ds1.11 this time around since it’s similar spec pad to dtc60 now it looks like there’s no other option for similar spec pad at least at this present moment only Ferdo 2500 which is not even close. That’s a bummer hoping these are not first sings off the end of the Lifetime replacement warranty program.
            The response to the rennlist thread states that the pads will be drop shipped from Feraddo which would imply I can get the ds1.11. As I said I’ll let everyone know what what their response is. I ordered these on Jan 6th BTW
              In that same thread, FCP says that they'll drop ship the same pads from another vendor to honor the warranty.
                I see, I have to contact them to see if at least I can get Dtc60 replacements I purchased before.
                  The response to the rennlist thread states that the pads will be drop shipped from Feraddo which would imply I can get the ds1.11. As I said I’ll let everyone m is what their response is. I ordered thes on Jan 6th BTW
                  Damn I missed it by couple days I ordered on the 10th and it was already to late.
                    I was basically told by via email that FCP would do a "like exchange" when the time comes which is totally contradictory of what the Rennlist thread states. The like exchange would be fine with me if they add some other type of track pad between now and when i need another set. As I just bought these and will not be needing replacements or a while I will cross that bridge when I come to it.
                      Just picked up another set after I sold my last set like a fool. Any consensus on Centric seal kits vs OG Brembo? Centric looks like $90-100 on FCP vs more like $175-185 for the Brembo seals and dust boots. Saving almost $100 is nice but would gladly shell out for the Brembo stuff if it’s better or easier to install.
                        Any chance anyone measure how long (mm or inch) are the brake lines for the fronts or rear?
                          Send an email to RalleyRoad. I'm sure he'd help you out
                            I added the finishing touch, finally got around adding the stickers, i was not going to bother but it does look better now that rears match the front stickers
                              Sort of answering myself after reading this thread again and Rennlist a bunch. There are enough negative experiences over there with Centric and Stoptech branded seals (which are not the same by the way) to scare me away from them for a safety critical item .. seals either too lose or too tight. Brembo is more like $400 so that’s out. The other two options are racingbrake for just under $300 and girodisc at just under $200. Seems like the Rennlist folks have good things to say about both, so I’ll be trying out the girodisc kits.
                                What caliper spreader tool are y’all using?
                                997.1 GT3 Carrara White/Black
                                C43 AMG Diamond Silver/Red​
