Originally posted by bigjae46
E86 Front Triangulation Braces Retrofit
With the caveat that I'm not really the appropriate sort of engineer and didn't FEA it, this was my original plan, but I got a little sketched out about the thread depth available given the size of the part (bearing in mind in my case the part is aluminium) and thought that Heinz's approach of having an insert that couldn't pull through seemed better to me.2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
Yep those are the onesOriginally posted by George Hill View PostAre these the studs in question? M10x1.5x20 and M10x1.5x30 from MRO?
https://mrohardware.com/product/m10-...-sfhh00m1030d/2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
Added the weight of the stock cabin air filter housing to the documentation (thanks OldRanger for weighing yours!).
Here's a screenshot of the data:
Looks like with the 3D printed strut tower brackets, this mod results in a net 909g (2lbs) weight reduction over the stock parts.
I haven't done the math, but just by eyeballing, it looks like the car's center of gravity will drop by a little bit (most of the weight savings come from the replacement HVAC plastics) and likely not move very much front to back (E86 braces are out front and windshield mount is out back)2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 4
Finally done with the carbon fiber version!
The strut tower brackets were a challenge. The issue is the 3rd mounting point. I can't find a moldable threaded insert that is shallow enough to clear the left side (wiring harness). I bonded a bolt and then ground down the bolt head.
The mold didn't go so well. I made the first half then I remove the base plate for the 2nd half. Like an idiot I removed the base plate and the part. So I had Heinzboehmer print another part. And then I made the mold into a wonky shape trying to be cheap and reduce the amount of urethane casting resin. Then I decided to be a cheap ass and try something cheaper which eh...worked.
The final part has some voids what are a bit of a concern. The cheap urethane won't allow for as much clamping pressure. I plan to shake down the car on labor day so we'll see if it falls apart!
Either way, I'll have to "invest" another $500 in casting urethane to redo this 😓
- Likes 7
This is so cool!Originally posted by bigjae46 View PostFinally done with the carbon fiber version!
Awesome! No spin around the paddock to get some driving impressions?Originally posted by bigjae46 View PostFinally done with the carbon fiber version!
Nope, not really interested in making money off of this. Doesn't feel aligned with the spirit of this community.Originally posted by Sajk View PostI have not followed the entire journey but is the plan to market these?
It's all open source, though, so anyone can recreate/tweak/improve for their own car. Info and links in the first post.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 5
Most of it can be 3D printed. I believe the piece that bonds under the windshield is pricey to CNC. Not sure about the strut tower brackets.Originally posted by Sajk View PostI have not followed the entire journey but is the plan to market these?
I can say that making the center bracket only cost me about $400, I could have saved $60 on shipping costs if I ordered enough casting resin the first time. So $340 - $320 for casting resin, the rest is carbon and epoxy. I used scrap carbon from other projects that I chopped up. You can buy chopped carbon for $50/lb. Epoxy will be the pain, can typically only buy it by the gallon.
It's been a while since I have ordered from them, but Fiberglast is good stuff and sells resin in smaller volumes.Originally posted by bigjae46 View Post
This category includes Fibre Glast's popular System 2000, high temp epoxies, surface coats, fairing compounds and adhesives. In stock for same day shipping.
Last edited by Bimma360; 09-01-2026, 04:26 AM.2006 E46 M3 Interlagos Blue ZCP SlicktopBuild Thread: https://nam3forum.com/forums/forum/m...6-m3-ownership
Drove yesterday and WOW! Now this includes Bry5on's wheel well braces and removing 10lbs of weight off the front end.Originally posted by heinzboehmer View Post
Same tired and worn out TC Klines...the car did not understeer at all! Usually the handling would be a mess in these conditions. There is a front end sharpness that I'd only get with fresh tires in much cooler weather. Can't wait to really push the car when it cool down.
I consider this a must do if you care about performance!Last edited by bigjae46; 09-09-2026, 08:44 AM.
- Likes 8
I really want to do this! Thanks heinzboehmer, and everyone that contributed to this. Lots of good ideas.
Our track car has the IHKA and cabin air intake removed - so I’m in that camp.
I have all the molds made if you want the brackets in carbon fiber...Originally posted by OldRanger View PostI really want to do this! Thanks heinzboehmer, and everyone that contributed to this. Lots of good ideas.
- Likes 3
I'd be interested, slowly trying to conceptualize and understand what's needed via the Word DocOriginally posted by bigjae46 View Post
I have all the molds made if you want the brackets in carbon fiber...| 06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|Bi-LED| TMS CSL Box|Megan headers|H.T.E Tune|Bryson Air Inlet|550 Injectors|OEM Section 1, 2, 3|200 Cell Cats|OEM SSK|Bilstein B12|712 yellow tag
