E86 Front Triangulation Braces Retrofit
    Why not just insert the helicoil and cut a threaded rod. On my carbon part, I molded threaded inserts and then used an M8 class 8.8 threaded rod cut to length. Loctite on the end that goes into the bracket.
    With the caveat that I'm not really the appropriate sort of engineer and didn't FEA it, this was my original plan, but I got a little sketched out about the thread depth available given the size of the part (bearing in mind in my case the part is aluminium) and thought that Heinz's approach of having an insert that couldn't pull through seemed better to me.
      Yep those are the ones
        Added the weight of the stock cabin air filter housing to the documentation (thanks OldRanger for weighing yours!).
        Here's a screenshot of the data:
Name:	Screenshot 2026-06-09 at 11.35.55 AM.png
        Looks like with the 3D printed strut tower brackets, this mod results in a net 909g (2lbs) weight reduction over the stock parts.
        I haven't done the math, but just by eyeballing, it looks like the car's center of gravity will drop by a little bit (most of the weight savings come from the replacement HVAC plastics) and likely not move very much front to back (E86 braces are out front and windshield mount is out back)
          Finally done with the carbon fiber version!
          The strut tower brackets were a challenge. The issue is the 3rd mounting point. I can't find a moldable threaded insert that is shallow enough to clear the left side (wiring harness). I bonded a bolt and then ground down the bolt head.
          The mold didn't go so well. I made the first half then I remove the base plate for the 2nd half. Like an idiot I removed the base plate and the part. So I had Heinzboehmer print another part. And then I made the mold into a wonky shape trying to be cheap and reduce the amount of urethane casting resin. Then I decided to be a cheap ass and try something cheaper which eh...worked.
          The final part has some voids what are a bit of a concern. The cheap urethane won't allow for as much clamping pressure. I plan to shake down the car on labor day so we'll see if it falls apart!
          Either way, I'll have to "invest" another $500 in casting urethane to redo this 😓
          Click image for larger version  Name:	IMG_6368.jpg Views:	0 Size:	82.5 KB ID:	365372 Click image for larger version  Name:	IMG_6369.jpg Views:	0 Size:	88.6 KB ID:	365373 Click image for larger version  Name:	IMG_6370.jpg Views:	0 Size:	74.3 KB ID:	365374 Click image for larger version  Name:	IMG_6371.jpg Views:	0 Size:	111.7 KB ID:	365375
            This is so cool!
              Awesome! No spin around the paddock to get some driving impressions?
                Not yet. I keep the car at the track and had too many other things to get done. I'm old and it's hot outside so progress has been slow.
                  I have not followed the entire journey but is the plan to market these?
                    Nope, not really interested in making money off of this. Doesn't feel aligned with the spirit of this community.
                    It's all open source, though, so anyone can recreate/tweak/improve for their own car. Info and links in the first post.
                      Most of it can be 3D printed. I believe the piece that bonds under the windshield is pricey to CNC. Not sure about the strut tower brackets.
                      I can say that making the center bracket only cost me about $400, I could have saved $60 on shipping costs if I ordered enough casting resin the first time. So $340 - $320 for casting resin, the rest is carbon and epoxy. I used scrap carbon from other projects that I chopped up. You can buy chopped carbon for $50/lb. Epoxy will be the pain, can typically only buy it by the gallon.
                        It's been a while since I have ordered from them, but Fiberglast is good stuff and sells resin in smaller volumes.
                        This category includes Fibre Glast's popular System 2000, high temp epoxies, surface coats, fairing compounds and adhesives. In stock for same day shipping.
                          Drove yesterday and WOW! Now this includes Bry5on's wheel well braces and removing 10lbs of weight off the front end.
                          Same tired and worn out TC Klines...the car did not understeer at all! Usually the handling would be a mess in these conditions. There is a front end sharpness that I'd only get with fresh tires in much cooler weather. Can't wait to really push the car when it cool down.
                          I consider this a must do if you care about performance!
                            I really want to do this! Thanks heinzboehmer, and everyone that contributed to this. Lots of good ideas.
                            Our track car has the IHKA and cabin air intake removed - so I’m in that camp.
                              I have all the molds made if you want the brackets in carbon fiber...
                                I'd be interested, slowly trying to conceptualize and understand what's needed via the Word Doc
