    Originally posted by jpy1980 View Post
    It kind of just clips back on from what I remember. If you only did one side, it could help by removing the other side and seeing how itโ€™s clipped on there.
    Thanks I must be overthinking something. When I clip in the white housing the latch doesn't seem to be grabbing the cable upon pulling the door handle.
    ๐Ÿ”น 2001 M3 Laguna Seca Blue
    Instagram: link
    Build thread: link
      Ok figured it out. The cable needs to be seated inside the two little gaps then they'll act as rails.
      Mine(as pictured) came unseated on removal.
      โ€‹Click image for larger version
      Instagram: link
      Build thread: link
        After 10 years and just 20k miles, I'm starting to think I want to pull my Bilstein B4s out and do something else--something that rides "better" on the street but still offers better handling performance; I don't do track days in this car. For shocks running with stock springs and hardware, what are some opinions based on current offerings? Last I paid attention years ago, the B6's affected ride height, the rear spring pad thicknesses were in play, and if I recall, maybe BMW had a spring change somewhere in 2003 resulting in some cars having a different ride height. CSL springs were in play at some point, Dinan springs were available. If there is a thread, or threads here I've missed, apologies in advance.
        You'll be hard pressed to decisively improve both ride and handling over stock without a really sophisticated damper ร  la ร–hlins DFV. Koni Special Active has a similar mechanism, though I get the impression it's not as good for more dynamic driving.
        Maybe consider Koni Yellows?
        2008 E90 M3 6MT
        Slicktop, no iDrive | ร–hlins by 3DM Motorsport | Autosolutions
        2011 E90 328i 6MT
        RWD, slicktop, no iDrive
          I have the Koni/Eibach setup with the settings on one click from soft. I have OEM bushing with the exception of the trailing arms which are Powerflex polyurethane and have 19" wheels. I very much enjoy this setup for DD. There is also a thread about this if you haven't seen it already. https://nam3forum.com/forums/forum/m...aily-driven-m3
            My vote is bilstein b6 with gc street plates to recapture travel. Springs - stock, eibach or dinan.
            Koni yellows never felt great to me, always disappointed. H&R and tein springs are trash.
            DD: /// 2011.5 Jerez/bamboo E90 M3 ยท DCT ยท Slicktop ยท Instagram
            /// 2004 Silvergrey M3 ยท Coupe ยท 6spd ยท Slicktop ยท zero options
              I kept things stock and went with Koni Yellows. I love the compliant ride and still feels good in spirited driving. I also refreshed all the stock pieces at the same time (FCA, FCAB, rear ball joints, RTAB, etc).
              I never track and do use my car to run errands or commutes so I didn't want a lowered / stiffer ride.
                You guys think it's weird to add a grab handle for the driver side? I always liked having it in the G35 years ago...I never knew why they had it on both sides...
                i did it on an old e46. it's nice when you just wanna change the position up on long drives.
                  These grab handles are kind of hard to find in black!
                  /// 2004 SG/IR - Build Thread
                    Need to check a (BMW) VIN, mostly for service history and ownership--what's the best outlet to do so nowadays?
                      Outside of Carfax, Autocheck and/or knowing someone at a dealer, has there been an alternative approach to this? Asking from a point of curiosity because those are the only ways I've ever known.
                      Build thread: Topaz Blue to Shark Blueโ€‹
                        I will be doing a pilot bearing on my E63 M6 soon, this is the same bearing as on the M3, I have never pulled or installed a pilot bearing and need a bit of advice.
                        I have seen different ways of removing the bearing, different tools, puller type, slide hammer type, stuffing bread intot the hole and pounding a punch in way.
                        As far as installation is concerned is OK to maybe find a suitable socket or better yet seal driver that fits the outer bearing race and tap it in?
                        Any thoughts, experiences or tool recommendations would be appreciated!
                          Can I get brakesperts opinion please? On the right side when braking I get a little squeak, I brake long, soft, and slow not hard it's just a daily driver. To me there's enough pad and rotor but I'm not sure if I need to replace them or not. Pic for reference.
                          Click image for larger version  Name:	PXL_20240317_233411520.jpg Views:	0 Size:	60.0 KB ID:	257957
                            Pilot bearing puller like this one:
                            Socket that contacts the OUTER race and hammer until it stops (I use a chrome 1/2" drive 23mm Matco socket).
                            Email to [email protected]
                              Karbonius CSL airbox question. My car has the version with plastic trumpets installed. I also have a new Race airbox with carbon trumpets. Any reason to use one over the other?
                                Nope, other than the Race will be a newer and a few grams lighter.
