This is a sticky topic.
    Anyone know of a way of getting a hold of the suction cups that are on the foam piece inside a kevlar front bumper? Cant seem to find anywhere to purchase. I unfortunately do not have my original front bumper
    Click image for larger version  Name:	proxy.php?image=http%3A%2F%2Fi.imgur.com%2FTpP6YKD.jpg&hash=eb1795eac6c3d74171b5caa2510dc478.jpg Views:	0 Size:	83.6 KB ID:	83045
      There used to be a guy on M3forums who parted out M3s...he usually had a good selection of parts. Does anyone remember his name?
        Mparts world wide, picked up a set from him.
          I understand they will not fit out of the box.
          I have the opportunity to purchase a used set for cheap (relatively). And given I'm doing my motor rebuild I'm thinking why not.
          Basically what I'm asking; if I take the V1 headers + my section 1 (Status Gruppe) to a local exhaust shop, they should be able to custom fabricate a flange or even flare the 2.25" pipes to fit the V1's no?
          Late reply, but the bigger issue is lack of space in that area. With the larger diameter V1 collectors, pretty much the only connection possible is the slip-joint which is why SS uses it. You may just want to buy the SS section 1 now. No exhaust shop labor either as it will bolt up to factory section 2 (no cats of course).
          Love your build, by the way, great job.
            It’s gonna be one of those “well duh” questions, but do you need all 4 locks on a hardtop or is it just as good with 3 locks? About to buy a hardtop but rear left locking pin is missing so was wondering if it’s safe to drive like that
              It’s safe to drive since it’s the rear. It just won’t sit or fit flush and rain water may leak inside.
                I know this has been covered before but I can't find the specific threads talking about it. For a diff fluid change, would this fluid be good to use?
                or is "genuine bmw" diff fluid the one that should be used. Normally I would just go with LM oil in everything but I think I remember reading about someone ruining their diff with that stuff.
                  Use Genuine BMW
                    You can add FM to that, the supposed % of FM in the OE BMW stuff is floating around somewhere. I recall that Motorcraft XL-3 (Ford's house brand) works for that.
                      Use Genuine BMW
                      I thought Genuine BMW was Castrol SAF-XJ + FM booster. SAF-XJ is now (or has been superseded by?) Syntrax Limited Slip, which has FM booster in it.
                      2008 E90 M3 6MT
                      2011 E90 328i 6MT
                      RWD, slicktop, no iDrive
                        The only retail Castrol syntranx I've ever been able to find (with FM in it) is the 75w90 bottle, not 75w140.
                        This:
                        Then all of the sudden, there's this:
                        Awesome! Too bad FCP doesn't sell it
                          https://www.amazon.com/Castrol-Syntr.../dp/B07KQFV3K8
                          Looks like they do, just in smaller bottles:
                            We've always known about those ya, but that's not the SAF xj + fm booster. I guess I assumed that the full liter bottle was a different formula with FM booster. Now it looks like they're the same thing
                            Oh well. The hard part is knowing if your diff is one that won't make noise with regular Limited slip additive found in retail products like the syntrax. Remember, not all Ms went back to the dealer to get the FM booster - it was described as "as needed" IIRC.
                            So do you try to save money, but then find that your diff is still groaning, so then you gotta get the BMW stuff? BMW stuff from FCP is probably still the best move.
                              Pretty sure that's exactly what it is.
                              SAF-XJ => Syntrax 75W-140
                              "Limited Slip" implies FM booster. Or, more accurately, friction characteristics suitable for limited-slip operation.
                              In the off chance your diff groans with this stuff, you can always add FM booster later.
                              2008 E90 M3 6MT
                              2011 E90 328i 6MT
                                Limited slip implies some type of friction modifier, not BMW's FM booster. Probably impossible to find out what exactly the additive is made of (most are molybdenum disulfide).
                                I've already played the game of trying aftermarket lubes and FMs - nothing works like the BMW stuff (in grey bottle with green top or clear bottle, grey label, red twist cap).
                                It's nice to see 75w140 castrol available in the U.S. now in the liter size, but it's not the same thing as BMW's saf xj + fm booster. Also, booster is a word to imply an extra amount of something. So it's more like SAF Xj with FM + FM booster. The syntrax would be like saf xj w/ some sort of FM.
