This is a sticky topic.
    Ok my dumb question.
    Was swapping back my eventuri intake, and one of my wireless earbuds, fell out of my ear while leaning over the engine bay and fell into engine bay, tried to use a telescoping magnet to get in back, but was too weak of magnetic force and it fell in deeper in.
    I don't care about the ear bud, just wondering if I should be concerned about that ear bud in the engine bay with the tiny lithium battery, not sure if it will fall into something mechanical. I can't tell where it went anymore, but here it's the area it fell into.
    Click image for larger version  Name:	PXL_20251012_195154729~2.jpg Views:	0 Size:	105.4 KB ID:	322692
    2004 M3 6MT |Eventuri Intake|
      There's really nothing down there to worry about, maybe with a borescope or small mirror/one of the those bendy grabber tools you could get it?
      If/when parts of it melt and you smell that.
      The throttle actuator is under the plenum, but the chances an earbud would gum up the works there are so remote I don't even know why I typed this!
        Fortunately I did have a borescope and manged to find the earbud. I ended up ordering a bendy grabber tool and should be here tomorrow.
        Thanks for the response.
          Well bendy grabber was a success was able to grab it without any drama. Im glad i was able to save my earbud and not smell burning plastic.
          recorded the action for fun
            Does anybody know if this is the rubber mat that fits in the long part of the euro tray?
            https://www.turnermotorsport.com/p-86240-51168242843-genuine-bmw-part/?gad_source=1&gad_campaignid=21128500759&gbraid=0A AAAAD_rX5aP8v2sYibcSG6tIJkCRBxGr&gclid=CjwKCAjwxrL HBhA2EiwAu9EdMxlJajkMH-UJNhjoVo3Udn-X2oJjZQ8a4_lxS8SSeTuIIrsV-4sc6hoCU1EQAvD_BwE
            What's the best flush spacer set up for OEM ZCP wheels?
              The owners manual says to not warm the car up by idling… but it seems weird to not let the carget up to temp. What does the hive mind say about this?
                Why ask this question here? Now the threads gonna erupt LOL.
                I have used the following rule since i started driving.....
                Summer: start vehicle let it idle for a minimum of 2 mins then start driving normally and no full throttle etc. until waters in the middle and oil near the middle.
                Winter/Cooler weather: start vehicle let it idle for a minimum of 5-10 (depends on how cold it gets where you are) mins then start driving normally and no full throttle etc. until waters in the middle and oil near the middle.
                The above formula works here for me in Bahrain for 29 years approximately. Also here summers are brutal 125f plus and winter don't really exist but i just call it nice weather....
                  I let it idle for about 1-2 minutes, then drive conservatively (keep rpms below 3.5k) until oil temp reaches 1/4 marker, usually about 10 min or so depending on ambient temps.
                    I let it idle for about 1-2 minutes, then drive conservatively (keep rpms below 3.5L) until oil temp reaches 1/4 marker, usually about 10 min or so depending on ambient temps.
                    SAme for me in summer plus i have the CSL warm up lights coded so that is a good helper too. Its so damn hot here even if i drove off after 1 min warm up the car will be up to water temps fast LOL
                      It will take longer to get to operating temp if you idle it, which also means the ECU will run the engine richer for longer and that can cause more fuel to end up in the oil, thinning it out. All bad stuff for a modern engine.
                      Fire it up, wait 10 seconds or so, and drive off with light throttle input while preferably keeping it under 3k RPMs. Once the oil temp starts to rise, medium throttle input and 4k RPM is fine. Once at operating temp (200F oil temp), rip it 8k RPM
                      Disregard the warmup lights on the tach unless you get them recalibrated. The warmup lights turn off a bit too quickly with the factory settings.
                        ^ This
                        Also, combustion quality sucks when the engine is cold, so there are a lot of byproducts that also end up in the oil.
                        Idling up to temp seems reasonable because you're running the engine as gently as possible until the oil heats up and isn't super thick any more. But it takes much longer to get to that point than it would if you just drove off, and in that time all the other problems with cold engine running are worse. So, on balance, better to give it just enough time for the oil to make it to the top end and then drive gently until everything's warm.
                        2008 E90 M3 6MT
                        2011 E90 328i 6MT
                        RWD, slicktop, no iDrive
                          Thanks everyone!
                            I just bought/received some TCK SA's and am out dicking around in the garge, I can very easily compress both front struts with one hand, even 2 fingers, and they won't extend back up on their own.
                            The rears I can compress, this takes notably more effort and they do extend back on their own.
                            My suspension knowledge is quite bad, but if any other strut did this I would tend to think only one thing, its blown out.
                            Tell me why I am wrong here.
                              It sounds like the fronts are done and need to be serviced. Usually, its the rears that go first.
                                Yeah, thats unfortunate as they are new, but shit happens, hopefully they have some working units in stock.
                                I really thought they were bad after test fitting a camber plate and just the weight of that almost fully compressed the struts.
                                Edit: After an email with TCK they say this is normal as the front struts are not filled with gas and therefore will not rebound, as long as there is resistance when pulling the strut back up, all is well.
                                I believe them, but a strut that doesnt rebound..? Whats the point, its all spring then.
