This is a sticky topic.
    Not sure if this qualifies for Dumb Q thread, but I'm negotiating a deal on a 2026 X5 xDrive40i, build to order. If anyone can provide insight into what a "good deal" is, I'm open to it. No trade, Performance Center delivery; should be an easy transaction but some of these dealers just insist on the add-ons, and just really seem to hold on to every penny. I know people have to eat and business is business, but this price discovery is painful.
    I'm in the auto industry and work with a lot of dealerships (not on the sales side) however from what I've noticed and have spoken to people, dealerships aren't going to negotiate as much as they did before COVID. I would expect the cheapest you'll find is MSRP. If the dealer won't let you buy for that and wants to keep adding stuff on, I would just keep calling dealers and find one that will.
    Because you're ordering the car, you have the benefit of choosing the dealership. Out of state/smaller dealerships will generally give you a better deal.
      I negotiated 3% off MSRP and no adds/fees beyond state legal max doc fees and will get an extra rebate from BMWCCA; pickup in SC at Performance Center. Man that was painful; haven't bought a car at a dealer in 10yrs. Oh, and I avoided the +$1300 MSRP increase for July production since this was a June allocation.
      Sreten trashed this thing on his channel, but it's to be expected. It's going to be my wife's car and she really likes it and I like it too. If anyone wants a clean, low mileage 2016 GX 460 message me!
        Does anyone know the size of CSL muffler tips? Are they different from US muffler tips?
        🔹 2001 M3 Laguna Seca Blue
        Instagram: link
        Build thread: link
          Is it still a bad idea to swap to a faster steering rack if you're on a MK20 DSC? I recall reading a few years ago that because MK20 can't be programmed to account for different steering ratios than the stock M3 rack, if you swap in a different rack you'll set off DSC constantly. Is this a solved problem or still the same now in 2025?
          Related question: anyone here rack swap a MK20 car and not regret it?
            I always turn of DSC anyways, but curious if it still is an issue with it OFF as well
              I've had two different MK20 cars, both with yellow tag racks. DSC doesn't seem any different to me. I turn it off if I plan on pushing the car.
                Is there a consensus on a replacement rear windshield (brand, availability, etc)? Looks like OE is NLA? Not finding much info on the rear, most threads are on the front replacement. I'm getting the windows redone and the shop talked about replacing the rear glass if the old tint won't come off. Hopefully it won't come to that but I'd like to be prepared.
                  Pick one up from a parts car. Glass techs should be able to remove the rear glass without damaging it.
                    Another glass question, this time the front windshield.
                    I am hoping to buy a new windshield but need to make sure I get the correct one, if it's available that is.
                    I know nothing about glass but pulled some #'s off the windshield, after looking at realoem and all the options I don't believe I have enough information to proceed.
                    Should I use a VIN decoder to find what P/N I need?
                    FWIW this is all the numbers on my windshield that I could find:
                    Pilkington 43 R-001047
                    AS M 83-3 DOT 25
                    E000201
                      Is there a common modification that requires a fused wire coming off of the positive jump terminal and then running to the cowling? I'll get a picture later if it would help in identifying the purpose of this wire.
                        Possibly angel eyes on the headlights.
                          It does have angel eyes. Thank you!
                            Has anyone tried running a csl map sensor tuned car with a stock(standard m3) intake? Curious if it would run for smog purposes.
                            Instagram: link
                            Build thread: link
                              Ok diff mount questions.
                              Are the rear mount torx bolts (inside the cover) one time use only or can these be reused?
                              Is there supposed to be a washer between the mount and where it touches the subframe?
                              Anyone have an objection to using a different style of bolt of the same size and grade if I can't fit a torx socket on there? I have CMP subframe mounts
                              '01 M3, Imola/black
                                Sure, you could, as long as you have the map sensor installed. I was able to pass smog in my state (Oregon) with a CSL tune. It depends on whether your state looks for modified code in the DME.
                                I've reused all my bolts without issue - however, I'm pretty sure they're all torque-to-yield and are considered single-use.
