    Still having paint issues with my carbon trunk, so a quick fix was bringing it to my detailer to wetsand the bubbled areas (entire top side of the trunk) and buff. Will need a repaint soon...Click image for larger version  Name:	9FB8EB33-7854-4BF4-A78B-273B328BA09A.jpeg Views:	0 Size:	216.0 KB ID:	106020 Click image for larger version  Name:	D4EAA769-E193-4702-B3DE-E457C6F3B104.jpeg Views:	0 Size:	84.5 KB ID:	106019 Click image for larger version  Name:	195539C8-42B3-48D3-A9D3-41C2B627DBBC.jpeg Views:	0 Size:	217.7 KB ID:	106018 Click image for larger version  Name:	CAE1EEF2-12EE-4BF5-952B-D3D145495988.jpeg Views:	0 Size:	60.8 KB ID:	106017 Still having paint issues with my carbon trunk, so a quick fix was bringing it to my detailer to wetsand the bubbled areas (entire top side of the trunk) and buff. Will need a repaint soon... Click image for larger version  Name:	77783E35-484D-4CAE-BDA4-C218F0BC7DAC.jpeg Views:	0 Size:	104.6 KB ID:	106016
      after and before of the issues I’ve been plague with owning a carbon trunk that gets parked outside. For now the m3 is back in the garage and the e30 got kicked out. Detailer/friend of mine worked a miracle getting it back to mirror
      Click image for larger version  Name:	B492C6AD-A445-4374-8D17-BF8510C13E44.jpeg Views:	0 Size:	264.2 KB ID:	106092 Click image for larger version  Name:	F0A852C2-94E4-40A9-9554-1A7F0261185B.jpeg Views:	0 Size:	118.6 KB ID:	106091 Click image for larger version  Name:	5C2A7D46-3899-4406-8832-949B3B78BF61.jpeg Views:	0 Size:	85.9 KB ID:	106090 Click image for larger version  Name:	CDE37FC0-C72B-4FA2-9428-C1633D47D955.jpeg Views:	0 Size:	81.3 KB ID:	106089
        This one is useful to those with TCK/GC/other coilovers where the damping knob interferes with the positive jump post on the right strut tower, forcing you to either run less caster/camber or make some sort of custom knob:
        Removed the jump post and reversed it so it's inside the drug bin, not out. A lot more clearance for the knob now:
          Compression pressure measured. It's uniform but very low, isn't it?
            Yes that seems low. 175psi is factory, above 150 psi is considered okay.
            Any symptoms that led to the test?
              a speed-dependent tack tack tack, the engine has 144,000 km
                When was the last valve adjustment? VANOS and cam bolts done? Rod bearings?
                  Mile end composite csl front bumper and ohlins r&t
                    I'm in the middle of replacing F/R rotors and noticed that one brake duct is totally covered and the other is partially covered (slotted). I'm confused 🤔
Name:	Brake duct covers.jpg
                      they aren’t really functional brake ducts. I wouldnt worry too much about them.
                        i had made a little keychain with some left over m texture fabric. really love how it matches the interior and is so simple. Click image for larger version  Name:	DSC_0006.jpg Views:	0 Size:	102.1 KB ID:	106912 Click image for larger version  Name:	DSC_0015.jpg Views:	0 Size:	104.4 KB ID:	106911 Click image for larger version  Name:	DSC_0017.jpg Views:	0 Size:	63.8 KB ID:	106910
Name:	DSC_0137 smaller.jpg
                          Very classy 👍🏽
                          -Singh
                          2004 e46 ///3 | Laguna Seca Blue | Black Leather | 6MT | Coupe | OEM+
                          BBS RC | Supersprint | Ground Control | Besian | Euro
                            Just remove them both.
                            -Singh
                              Differential flush & refill, new tie rods and boots ( along with alignment ), headlight leveling sensor bracket, new coolant reservoir and headlight washer pump. Next will probably be check/adjust valve lash and replace all 3 differential bushings. I'll have to remove the diff, and am wondering if anyone has used Rogue Engineering's replacement front bolt kit? Is it really that easy to strip the threads on that front bushing mounting hole?
                                I told mine that his new Apex wheels were on back order.
                                so he started stalling w/o CEL. Looked for codes and found a code 50(1144?)DME Switch chain, frictional connection.
                                Funny guy.
