Finally got the AFR issues figured out... the ICV was stuck open and leaking into the intake. A cleaning seemed to fix it.
What were your AFR issues, and had you previously cleaned the ICV?Originally posted by EthanolTurbo View PostFinally got the AFR issues figured out... the ICV was stuck open and leaking into the intake. A cleaning seemed to fix it.
I had a bank 2 lean code last fall I'm still wondering about. Cleaned my ICV about 2 years back.2004 Silbergrau Metallic 6MT
Once the car warmed up, EML would come on and cause it to go into limp mode. It would cause the AFRs on idle to go really lean, and bank 2 had way more smoke coming out of the tail pipes. This is my first time cleaning the ICV since I bought the car in Jan 2020.Originally posted by Cubieman View Post
I had a bank 2 lean code last fall I'm still wondering about. Cleaned my ICV about 2 years back.Instagram: @logicalconclusion
They are NHK V projectors. Most parts sourced from Caesar @ Lightwerkz. DIY install.Originally posted by GreyM340i View Post
What kit is this? Not from lightwerkz correct?
I posted a short night time video on my IG (@limited.slip). They are amazing!IG: @limited.slip
Alpine White E90 M3 6MT
Alpine White 1 Series M
T̶i̶t̶a̶n̶i̶u̶m̶ S̶i̶l̶v̶e̶r̶ E̶3̶9̶ 5̶4̶0̶i̶ M̶-̶S̶p̶o̶r̶t̶ T̶o̶u̶r̶i̶n̶g̶ S̶6̶2̶ 6̶M̶T̶
CSF seemed to have mixed reviews. The e90 crowd love the D008. Zionsville is the best? but $$$. ACM had a sale that made it hard to pass up.Originally posted by Cronenberged View Post
So from your rabbit hole what made you decide on D008?
I’m finally getting to work on the M3 Wagon project. It’s in the body shop and they are working on the under carriage - I need to get the front and rear suspension together so they can get the car on the ground and position the fenders around the wheels to make sure everything looks right and is even before they start welding them in.
This morning’s project was to get the rear subframe ready - I forgot how much fun it is to get the OEM bushings out. 🤪'01 M3, JB/IR, SS, TCK DA, Apex, TMS CSL, HTE, 4:10 gears - original owner
'00 slicktop Touring converting to full M3 Touring
Fuel lines ruined my day today lol. I gave up dropping the fuel tank because I could not get the fittings on the evap line 16117176511 to come off. The little blue neck on the tank itself began to flex and I saw dollar signs so I stopped. Aside from penetrating oil to loosen it up, any tips? The line is like $360
so it would be great to not have to cut it. And I really do not want to damage my fuel tank.
Penetrating oil and get an o-ring pick to get inside the hose. You lift hose from nipple than shoot oil or lubricant like PL100 and try to rotate the hose on the nipple.Originally posted by Nate047 View PostFuel lines ruined my day today lol. I gave up dropping the fuel tank because I could not get the fittings on the evap line 16117176511 to come off. The little blue neck on the tank itself began to flex and I saw dollar signs so I stopped. Aside from penetrating oil to loosen it up, any tips? The line is like $360
so it would be great to not have to cut it. And I really do not want to damage my fuel tank.2003.5 BMW E46 M3 Laguna Seca Blue / LSB
Disconnect them in the wheel well and pull them through the body when you drop the tank.Originally posted by Nate047 View PostFuel lines ruined my day today lol. I gave up dropping the fuel tank because I could not get the fittings on the evap line 16117176511 to come off. The little blue neck on the tank itself began to flex and I saw dollar signs so I stopped. Aside from penetrating oil to loosen it up, any tips? The line is like $360
When I drop a fuel tank I don't even pull the backseat, you can get everything from the bottom.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Email to [email protected]
