    Originally posted by sd561 View Post
    well, i finally did the thing and it's all done. This was pretty seamless and that would have been impossible without the support of this forum. Special thanks (enormous understatement) to karter16 Bry5on heinzboehmer bavarian3 Slideways for their help - i reached out to each with stuff and the level of support is kinda unreal. we are a lucky lucky community.
    what a glorious day it is. fitted the following:
    - plain weave karb race w oe-style hardware
    - Euro 02 harness, euro bracketry for 02s, genuine CSL air-rail and MAP in its factory spot (using MAP/IAT to MAF harness)
    - Genuine CSL headers
    - "Custom" Euro Section 1 courtesy of Gt4
    - replaced Conti DWS06 with some fresh PS4S (235/265) + cursory alignment
    have only put 30 or so annoying rush hour/stop n go miles but this weekend we will address this. Car feels and sounds ah-mazing just around town. not lumpy farty or anything weird, and it was slog just now in a scorching 94F at 530p
    enough talk here's pics of my box. in case anyone notices i am replacing that hideous thick not-OE corrugation next to TPS; i see it, i hate it
    [IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/i.imgur.com\/4bNrCzJ.jpeg"}[/IM2]
    [IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/i.imgur.com\/sc8AVae.jpeg"}[/IM2]
    [IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/i.imgur.com\/m2J3to9.jpeg"}[/IM2]
    [IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/i.imgur.com\/ZX0XZF3.jpeg"}[/IG2]
    Love to see it. Enjoy!
    🔹 2001 M3 Laguna Seca Blue
    Instagram: link
    Build thread: link
      Awesome stuff!
      Was the "custom" in Euro section 1 in that you had a euro sec 1 built or a genuine euro section 1 modified?
      Also, how does your R.E brace fit in regards to the plates> strut towers?
      Mine has a decent gap on either side, about the innermost 1/3rd of each strurt tower top.
        What a transformation! Any clearance issues between the RE Racebrace and the airbox?
ID:	366771 Click image for larger version
ID:	366772 I know it doesn't look like much but needed to carry a torque wrench without the entire tool box and a special deep socket as I am on wheel studs and locks.
          Carved the existing foam and my wrench is secure without taking up any extra space. You can do this for a breaker bar as well. etc...​
            Awesome stuff!
            Thanks. I believe it’s originally a USDM E85/Z4M Section 1, which is catted in addition to its headers, and the S1 has higher flowing cats than standard euro spec for e46. As I recall, it was custom fabricated to fit E46M by Gt4 who sold it to me; perhaps he will validate my schpiel
            im embarrassed to admit I never even noticed the gap on the RE brace fitment. Would describe it identically to yours. Don’t love this tbh.
            06 ZCP Individual Sapphire Black Metallic
            ig: na_csl
              none whatsoever. I just took a crappy pic real quick, not sure if it helps.
              ig: na_csl
                This is correct. To fit a Z4M OEM catted section 1 to an E46 M3, you have to shorten the pipes before the cats by 3" and rotate the flanges beween section 1 and 2. Than it fits! I also add O2 & EGT bungs
                Z4M section 1 are usually in better condition than E46 M3 euro one
                  Since I now have euro headers and section 1 I installed the euro program/tune 211323002001J424 .
                  1. Get the MSS54 DS2 Tool https://nam3forum.com/forums/forum/m...sh-counter-etc
                  2. Go to "DME Read" in the app.
                  3. Back up the Tune
                  4. Back up the program
                  5. Make sure your battery is charged and stable. I recommend power supply mode on a charger if you have one.
                  6. Download the Program "Full 211323002001J424.bin" from https://github.com/saildot4k/MSS54-X...20Full/MSS54HP
                  7. Download the Tune "211323002001J424 (EU3 6MT).bin" from https://github.com/saildot4k/MSS54-X...MSS54HP%20Bins
                  8. Go to "DME Programming" in the app.
                  9. Under "write program" select the "Full 211323002001J424.bin" you just downloaded and click "write program".
                  10. At completion I received an error message "program control: 'finalize programming' returned verify byte 0x0E. program and data references do not match'. I ignored this, perhaps because tune is not yet loaded.
                  11. I exited and restarted DS2
                  12. Go to "DME Programming" and under "write tune" select "211323002001J424 (EU3 6MT).bin" that you previously downloaded. Click "write tune".
                  13. You're done. You can check your version under "DME Info". Big thanks to karter16 and his helpers for creating this.
                  Click image for larger version  Name:	IMG_1560.jpg Views:	0 Size:	89.4 KB ID:	366853
                    3. Back up the Tune
                    Thanks for posting the detailed steps! Would be interesting to see what your impressions are before and after the updated program/tune.
ID:	367051 Click image for larger version
                      New inner fender liners for the sedan!! New pads, rotors next. I used 330I front brakes for my swap b/c the rotors are the same size but lighter.
                        After driving the car for a few days I can say the differences are very subtle, nothing dramatic. The butt dyno can feel a little more pep, but again its super subtle. I'm euro headers, euro section 1, stock section 2, and stock suitcase muffler. I can also say its perhaps a little smoother through the RPM range after application of the euro tune.
                        I do like the rasp better under the euro setup but that is subjective.
                          Click image for larger version  Name:	IMG_1994[1].jpg Views:	0 Size:	122.3 KB ID:	367082 Click image for larger version  Name:	IMG_1995[1].jpg Views:	0 Size:	115.9 KB ID:	367083
                          Got the HARD motorsport E46 Dash block off panels installed today.
                          Click image for larger version  Name:	IMG_1997[1].jpg Views:	0 Size:	103.2 KB ID:	367084 Click image for larger version  Name:	IMG_1999[1].jpg Views:	0 Size:	119.0 KB ID:	367085
                          Removed the last bit of the sound deadening from the trunk area, to prep it for Turtle Labs spare tire well and battery delete. (sedan) Heat gun, acetone is the way! If you are curious why the spare tire well is smashed in, I had to clearance it to fit Hotckhis sway bars. Stock M3 bars will clear the spare tire well, Hotchkis wont!
                            If you're up for it, bigjae46 has a mold and can make carbon trunk floors as well @ 3.5lb
                            My car is the guinea pig:
                              Maybe if it was a flat drop in panel, I don't need the impression. The Turtle Lab aluminum panel is 3lbs @ $115, that is pretty hard to beat.
                                I recently moved to the Portland area and attended my first BMW CCA Oregon Chapter meet up and got to park in "history of the M3" row. It rained the whole time but was still a great time and lots of fantastic enthusiasts.
