    Originally posted by Petener View Post
    Replaced motor mounts.
    How hard was it? I want to DIY mines but haven't been able to find a decent guide.
      Painted my RGR’s black just to see lol. They’re shadow chrome now.
        as an owner of silver bbs rgr's no lol.want to see shadow chrome though.
          Very easy and pretty straightforward. Just remember to remove your fan shroud and fan when lifting engine.
            https://drive.google.com/file/d/1_NE...w?usp=drivesdk
            Youtube DIYs and more
              Patience my friend. Pics coming soon!
                Smog done, now on to some maintenance. Engine mounts, front/rear control arms and bushings, rtabs, figuring out the weird bang/clang from driveshaft/diff (hopefully just the front poly diff bush busted). Then onto figuring out next tire set (after delaminating Fed RS Pro), playing around with Coolerworx Pro shifter, and at some point finishing the interior after the panel delete.
                Obviously putting ssv1/cats/tune back on with all this.
                  Cleaned all underneath the car getting ready for new liners.
                    Finished the install of the Stoptech C43 Ultra Lightweight kit.
                      What was your method? I've got the driver's side no issue...but struggling to get the pass side lifted.
                        At the front of the block on pass side there is a "horn" that I stuff a piece of wood on a jack under. I also use an engine bar, but you can get it up at that spot.
                          Front control arm job is a hoot, especially with that 21mm. Spent many hours and had to bust out the torch.
ID:	79157 finally got rid of the stock 19s
                              Curious, what did you use for the black paint, looks really good, at least in the photos.
                              Also, what are the specs on them?
                                Changed from Liquimoly 10w60 to Redline 5w50 today. I did the oil change differently this time: I sucked all of the oil out of the engine through the dipstick with a pump instead of doing it through the bottom, then I changed and lubed oil filter, and added new 5 quarts of new oil. The Redline does seem quieter but that might be due to the freshness.
                                Instagram: @logicalconclusion
