Originally posted by heinzboehmer
Coming back to this.Originally posted by heinzboehmer View PostI don't want to start randomly throwing parts at the problem though, so I'm gonna rig up a pressure tester and grab some data first. Pretty sure I have a spare oil fill cap somewhere, so should just be a matter of drilling and tapping a hole for a pressure gauge. Stay tuned.
I did not, in fact, have a spare cap in the stash, so I ordered a cheapo one.
Turns out the cheapo cap is hollow inside:
Slathered a bunch of RTV on the threads to try and salvage this attempt:
But I'm not at all confident that it will seal. Think it's highly likely that the next update on this effort involves a CAD screenshot of a custom cap with NPT ports on it.
The best part is that I replaced that crush washer a year or so ago because it was leakingOriginally posted by George Hill View PostI'm seeing this more and more, somehow the timing chain tensioner starts to leak through the crush washer. I don't understand the physics of it, but I've replaced a bunch of tensioner crush washers recently.
If that crush washer ends up being part of the problem, I'm not sure how I'm gonna fix it.
Maybe machine a groove in the tensioner to seal with an o ring instead?
Edit: I wonder if the uptick you're seeing is because most cars are no longer on the original crush washer and torquing the tensioner to spec in the engine bay is not easy?Last edited by heinzboehmer; Yesterday, 08:25 PM.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
What brand?Originally posted by heinzboehmer View PostThe best part is that I replaced that crush washer a year or so ago because it was leaking
You may be right. I've installed thousands (?) of crush washers and I can generally "feel" them crush. I've also reused them, without issue, but if they aren't getting crushed fully or are reused then maybe?Originally posted by heinzboehmer View PostEdit: I wonder if the uptick you're seeing is because most cars are no longer on the original crush washer and torquing the tensioner to spec in the engine bay is not easy?
Its actually super easy to torque with the right setup: 3/8" flex head, 3/8 - 1/2 adapter, 32mm socket. Tons of room.
Email to [email protected]
- Likes 3
Have your seen a variety of results based on crush washer brand? That always seemed like a safer area to cheap out (just a circle of copper), not that I've actually been able to sell myself on doing it.Originally posted by George Hill View PostWhat brand?
Not specifically, but I have replaced many non-OE crush washers that were leaking, I just don't know if it was a prior install error or part issue.Originally posted by Obioban View PostHave your seen a variety of results based on crush washer brand? That always seemed like a safer area to cheap out (just a circle of copper), not that I've actually been able to sell myself on doing it.
I have reused drain plug crush washers... a lot in the past with no know issues.
I'm not going to claim to be a metallurgist but its my understanding most BMW crush washers are aluminum is they are silver and copper if they are copper colored.
Now that I type this out it seems like BMWs are either copper M12 and smaller and silver/aluminum M14 and larger? As it relates to an S54, example:- Copper - Drain plug, valve cover drain liner, vanos accumulator line, etc
- Silver/Aluminum - Tensioner, P/S Hoses, Rocker arm plugs on the back of the cylinder head, coolant drain plug, Upper T/C rail pin,
In this situation, 07119963418 is the T/C tensioner crush washer. On ECS:- Genuine - $1.99, aluminum
- Elring - $2.03, copper
FCP has a $0.59 optionOriginally posted by George Hill View Post
(again, I've only used OE on my car, because because the price diff isn't worth the potential headache)
In the oil and gas industry, we carefully inspect any seal or gasket. The worst are the metallic spiral wound gaskets. Any nick, gouge, or damage renders the gasket defective. In that case, a leak at minimum causes expensive rework and downtime. At worst it causes a large release of highly flammable material.Originally posted by George Hill View Post
I'd inspect those crush washers. I'm sure they are not handled carefully from the manufacturer to distributors to retailers to end user.
Either way I wouldn't pick a $0.59 aftermarket part EVEN if it was labeled OE over a $1.99 genuine part.Originally posted by Obioban View PostFCP has a $0.59 option
Only works with copper crush washers. Heat with a torch until just glowing red and then submerge in water.Originally posted by maupineda View Postthe key with these soft metal crush washer is to make sure they crush, you can anneal them with a torch, and they become super soft and seal perfect. this was how I was able to stop my leaky tensioner.
I'll ask my metalurgist father, but I think it would apply to all or most alloys, not just copper. Some crush washers provided in various kits look to be aluminum at times, not always copper.Originally posted by jayjaya29 View Post
Only works with copper crush washers. Heat with a torch until just glowing red and then submerge in water.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
probably made in the same warehouseOriginally posted by George Hill View Post
AFAIK, the aluminum ones should not be reused (although I have gotten away with it a couple times), but the heating method will not work like it does on the copper ones.Originally posted by Tbonem3 View Post
Only copper gets softer with quenching! Pretty much every other metal has the opposite effect and should be air cooled. Pretty weird.Originally posted by Tbonem3 View Post
I'll ask my metalurgist father, but I think it would apply to all or most alloys, not just copper. Some crush washers provided in various kits look to be aluminum at times, not always copper.‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
