Tyler's 04 slicktop 6spd Silvergrey MCS/Brembo/CSL/Karbonius/Nogaros/Supersprint
    Hmm, Vince has you keep the threads for his products. You drill up into the trunk with a drill bit that's the same size as the minor diameter of the subframe bolts (~10mm for M12x1.5) and then tap the rest of the insert so you can run the longer studs through. (...)
    Confirming this 👍
    IG: @limited.slip
    Alpine White E90 M3 6MT
    Alpine White 1 Series M
      Would this car ever be for sale?
        Doubtful, but never say never. Don't see it happening any time soon.
          Before installing the sect 1, I routed the O2 plugs through a hole in the heatshield (made when I had euro cats) and run along the tunnel, driver side
          Click image for larger version Name:	silvergHJSgiubo13.JPG Views:	0 Size:	101.1 KB ID:	147812
          Hello
          Click image for larger version Name:	silvergHJSgiubo14.JPG Views:	0 Size:	179.2 KB ID:	147815
          Once the pipes are installed, I pulled the O2 plus as far forward as possible, to meet the harnesses that need to be run behind the airbox and down tranny/clutch line area (already done in 2014). They'll reach a bit past the tranny brace. It's actually a good area for them to meet the harnesses as there are already some clips for the wiring of the tranny sensors.
          Click image for larger version Name:	silvergHJSgiubo15.JPG Views:	0 Size:	39.4 KB ID:	147814
          I think this is the part I'm not understanding. Are you just showing the process of where the male ends of the harnesses got routed through ?
            Yes, at least in that post, there are no pics of any of the routing from engine to transmission as that was done back in 2014. I want to say I had some more pics/info at the time back on m3forum, but when I had to recreate this thread, I don't think I put the info in. I'll check to see if I have any pics from back then. I remember a thread on this forum with more info though, if you want to try searching.
              I've lost count how many time's i've viewed this thread to keep up with your updates - such a clean and meticulous build!
                Thanks bro! Sadly, no updates for a while, not that there's much left I want to do to the car.
                  I live in fear of this. I have this niggling concern that once I get the car "perfect" I'll no longer be interested in it 😋
                  2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace
                  Build Thread:
                    Worry not! It's only being married and having kids (esp the 2nd kid) that has curtailed my hot modding streak. I can do this shit forever. Tho the trick might have to be to keep getting more m3s to work up
                      haha too true - 2nd children are something else haha 🤣
                      Build Thread:
                        Bi-annual SMOG test
                        I posted the same thing, basically, 2 years ago, but I have something new to document this time 'round. Here's everything (hardware-wise) that I swap for the test:
                        Not that I drive it much nor are conditions extreme, but the inside of the (karb) box looks brand new still as does the OE filter. TBs still pretty as well and those I cleaned like 8 years ago (20k)
                        All set, hardware-wise. Doesn't take long at all. Now to tune.
                        I've been tuned for about 8 years and have flashed back and forth probably twice that many times. I was starting to get close to the flash counter and, obviously, didn't want to brick the ECU, so I went ahead and finally purchased MSSflasher so that I could reset the FC, and flash faster than BMWflash (free) can do.
                        Smooth sailing
                        While flashing my alpha N tune (Evolve-R) back to the car, I wanted to lower the front just a tiny bit. After going down to 343lb rates in the front, I'm still playing with how low I can go without scraping the car in some of my favorite sections of canyons out here. I don't love how the car looks at 13.5" and above, but I know the car needs travel. Luckily I've the hardware and enough spring/light enough car that gives maximum travel, but lower ride height.
                        Took the opportunity to check on my new HEL brake lines, looking perfect particularly the rubber grommet that holds the line to the strut. The cheaper lines' grommets just crumble in my experience and don't fit too well anyway. HEL is perfect!
                        I was waiting until the next time I had the strut brace off to install my MPOWAAAAA decal to the airbox.
                        Light polish and clean
                        Look at the weave. Just look at it.
                        Measured and marked
                        Proper
                        Next thing to do will be a decon, perfecting polish, and application of ceramic coating, most likely Gyeon Pure Evo that I still have about 40ml of (used 10 on the E90's E88s), but I'm still building out my garage and suffering through a kitchen remodel, so it may be a little while plus the E90/X7 are getting more focus these days :/
                        Coming up on 15 years of ownership later this year. Still gives me big feels
                          Bi-annual SMOG test
                          Smooth sailing
                          Measured and marked
                          Proper
                          Great update T
                            Another round of miscellaneous updates.
                            Did an oil change in Nov '24. The garage is still full with remodelling bs, so I'm still working outside
                            Still had a half bottle of Castrol to use up, but I'm now buying Motul power ester 5w50 for both this car and my E90
                            Then I finally finished my rear shelf setup, or at least so I thought, until I realized I still need the blind plugs for the headrest holes doh! Thanks to Avedis for the trim blanks and idea!
                            I've been dedicating all of my free time lately to finally getting comfortable using BMW standard tools (NCS/winkfp/INPA/etc). My E90 needs a lot (TPMS delete, battery coding, DCT tune, engine tune), so I started reading every forum and guide I could find.
                            Anyway, my E46 is already pretty set up coding-wise, but there was one thing I did want to do, and now I have the knowledge and tools to do so: Mtrack mode for mk60 dsc (non zcp) retrofit
                            Added ZCP $7MA to the VO via NCS Expert, then coded defaults to kombi and DSC. Then, since I have 996 brakes and ZHP steering rack, I decided to keep the ZCP parameters as I think it'll match up best. my 11/2003 doesn't have the cluster for Mtrackmode, so I did have to edit the trc file for the light (so I will see DSC light for MTM and DSC+BRAKE light for DSC-off).
                            Pictured above is DSC fully off. My only issue here is that, with the DSC yellow triangle and circle illuminated, I won't have a visual indicator that DSC is intervening (in MTM). Ofc, I should feel the brakes pulsing or fuel being cut, but I did like to see the DSC circle flash when DSC would intervene. I'm not gonna bother with the stalk retrofit.
                            I don't drive the car very often, but coincidentally, a local E46 guy, Italo, spotted me on the 101! Always fun to see your car captured by others.
                            Last but not least, I made a little video of some recent actividades:
