    So I ordered some Alcantara soft today to make myself an insert for the CSL centre console. Shelling out for a genuine one seems excessive so will go the route of making my own. I'm planning to 3D print a template to trace with a blade to cut the piece out.
    The other thing that I'm planning to look into on a (literal) rainy day is a script to intercept files coming across FTP from the Gauge.S and to rename them sequentially. One of the issues with Gauge.S is that if it doesn't have the current time from a time server it reverts to an incrementation-based naming convention based on what files already exist on the SD card. This means you end up with a bunch of files named something like GaugeS-1.csv with no easy way to tell which is which. If you happen to be connected to wifi at the time the log starts it's all good. The other way to address this is to use the GPS module to acquire the current time.
    I suggested to Sorek that a useful little option would be to store a global variable on the SD card with the current file increment. That way it could persistently assign the next increment, regardless of what files still existed on the SD card. Unfortunately Sorek advised he wouldn't be doing this as he considers it "clutter" and that his solution is to buy the GPS module. Given I have no other need for the GPS module I refuse to use that much hardware to solve such a simple problem so will look to solve this server-side on the FTP server.
    Build Thread:
      Any chance you’d share the STL of that ash tray insert once it’s done? I’ve been looking to print something similar!
        Originally posted by Arclitgold View Post
        Any chance you'd share the STL of that ash tray insert once it's done? I've been looking to print something similar!
        Yep for sure, will be happy to share once I've got it sorted. Worth noting that the version I'm currently working on is for RHD Cars. I could do a LHD one fairly easily, just would need to be mirrored and have the layout of the retainer changed to accommodate the fact the board itself stays the same (ie not mirrored).
        Also thought I saw a post here from Avedis but it seems to have disappeared. Anyway, the answer is that I'm planning to measure the size of the tray and cut the insert to fit. Happy to share the measurements once I've got it nailed.
        Build Thread:
          Does this help in the meantime? https://cad.onshape.com/documents/40...f5b6a01462b639
