Wow that came out miraculously well. Nice job.
Nice job! But maybe you will have the same problem as I do, you can't properly open the false floor now, because it could get stuck against the bracing.
Only a problem if you often want to access the tools below or store some stuff between there.
But I will have to make bigger cutouts sometime because it's little bit annoying.
Yeah it's a good point - I accounted for this enough with mine to mean I can lift the floor up enough to get the tray out without having to remove the floor, but you can't tip it all the way up to the trunk lid. Good point though to remember this when doing your cutouts.Originally posted by rtrules View PostNice job! But maybe you will have the same problem as I do, you can't properly open the false floor now, because it could get stuck against the bracing.
But I will have to make bigger cutouts sometime because it's little bit annoying.2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
