    Continuing to make good progress towards getting this releasable.
    heinzboehmer and Bry5on have kindly user-tested and given me excellent feedback to help improve the app and make it as user-friendly as possible. Laundry list of updates below:
    • Fixed an edge case that cause DS2 commands to be interleaved causing a connection drop
    • Added dialog to prevent app closure while DS2 connection active, if a wipe/write action is underway the user must wait until it is finished in order to leave the DME in a clean state, in any other state the user can choose to disconnect and close the app.
    • Added the Flash Counter control to the Write page for better visibility, also warn the user if they attempt a write action with less than 5 flash slots remaining.
    • Added graceful handling of cable/interface disconnection within the app.
    • Found an issue with the Cancel button and ensured it now waits for the current DS2 command to conclude gracefully before cancelling the action.
    • Disabled the cancel button while erase/write activities are in progress.
    • Added full validation of Data/Program binaries. The source file is checked for version information and the app will not allow writing a program file that doesn't match the bootloader on the DME and likewise won't allow writing a data/tune file that doesn't match the program on the DME.
    • Improved coverage of logging messages.
    • Finished the Settings page.
    • Relaxed validation (with extra user warnings) when restoring the Service segment (AIF, etc.) to allow restoration when the AIF region has been corrupted and the DME variant and VIN cannot be determined.
    • Added better handling when the user connects but the car ignition is not on.
    • Bryson noted that for a first time user the entry into fast read, and then the subsequent read of a tune file takes about the same amount of time as just reading the tune at 9600 baud. Have expanding settings to allow user to independently toggle fast read on and off for tune/program reads.
    • Resolved a misunderstanding on my part about the persistence of the ZIF backup.
    So what remains? More testing. The app has been pretty well tested on MSS54HPs, it needs testing with MSS54s. If Heinz gets a chance I think he's going to give it a go on his backup DME, if anyone else has a MSS54, the ability to BDM it if it all goes horribly wrong, and is game to be a guinea pig then let me know :-)
    Build Thread:
      Id be interested in giving it a shot on an MSS54, but I don't have a way to BDM if needed. BUT I'm not worried about that as I have some spare DMEs and nothing critical in use. What do you need from me? Shoot me an email [email protected] if its easier.
      Will there be an option to virginize the EWS, so we can sync a used DME with a "new" to it car?
      Email to [email protected]
        Awesome that would be great thank you! First round of testing will be read-only anyway, as those logs should give me a fair idea of how it's all looking. After work my time I'll add you to the google drive folder that I'm using for the beta files and will flick you an email with some testing instructions - thanks very much!
        Yep there will be for sure. Not as part of 1.0. I'm trying to quickly finish the current feature set and get it out there and then can iterate with additional features. Virginization and EWS sync are high on the list as appreciate this will be useful for quite a few people.
        Build Thread:
          karter16 Would the DME be wiped if we reset the flash counter only?
            Nope, the software takes a backup of everything that's in that segment of memory, wipes the segment, and then writes everything back except the bytes specific to the flash counter.
            Build Thread:
              That is great! Thanks again.
                So I possibly lied...
                Reading/clearing error memory proved surprisingly easy to build out. I started with a quick PoC cause I was interested and it was so successful I just finished it.
Name:	Screenshot 2026-05-06 at 4.15.48 PM.png
                Also added in support for sensing the KL30 and KL15 lines cause why not.
Name:	Screenshot 2026-05-06 at 4.17.59 PM.png
                Build Thread:
                  Sounds like the next quick feature add is to build out the entire test suite that makes up INPA and DIS?
                    hahahaha stop giving me shiny things to chase. I need to finish this current shiny thing first
                    Build Thread:
                      Okay - Lots of updates.
                      George Hill has very patiently tested reading/writing on an MSS54 and helped resolve several issues. I made things worse yesterday by rushing trying not to waste his time and ended up wasting more of his time with dumb mistakes 🙈. Anyhow George has confirmed reading/writing is now working and the logs look great!
                      I've also been unable to resist adding some more features this week:
                      Re-worked connection screen to help guide users through the connection process. Essentially plug in your cable, turn ignition on. The app will detect ignition when it's active and automatically connect and begin the query process.
                      Click image for larger version  Name:	Screenshot 2026-05-10 at 8.33.55 AM.png Views:	0 Size:	77.3 KB ID:	354904
                      Ability to read and reset adaptions is now implemented:
                      Click image for larger version  Name:	Screenshot 2026-05-10 at 8.44.11 AM.png Views:	0 Size:	231.9 KB ID:	354905
                      And Recycle DME (virginisation), EWS Re-sync and EWS Initial Sync are now implemented, but untested. George is planning to test the Recycle DME and EWS Initial Sync features when he gets a chance.
Name:	Screenshot 2026-05-10 at 8.35.12 AM.png
                      The app is now converging around a stable feature set. I'm hoping to finish getting things tidied up and am aiming for an initial release next weekend!
                      Oh, one other thing, in his testing feedback Bry5on noted that programming mode is slightly inconvenient in that to get out of it (and regain access to features that are blocked in programming mode) it is necessary to power-cycle the ignition and reconnect the app. I've got to do some experimenting but I think I've found a way for the app to reboot the DME and auto-reconnect to it which, if I can get it working well, I will also implement.
                      Build Thread:
